MTD 990 Spindle replacement
5 replies to this topic
#1 altaguy OFFLINE
altaguy
  • 2 Thanks
  • 1 posts
Posted June 28, 2016 - 06:52 PM
Hey All,
                  New to the forum. I have a 76 16HP Turf Trac garden tractor that works great. Model 146-990-502. It has the snow blade, tiller, snowblower and 50" mower deck. I have only had the mower deck attached to it and it does a great job. (Or I should say did!)
I am in need of new deck spindles for this deck (I hit a rock and stripped the threads on 1 but want to replace all 3) and was wondering if there is maybe a new style that will work or do we need to get NOS or used. Also, would it be a problem for a machine shop to fabricate new ones or would that be really expensive? I was thinking of maybe having new ones made that used a keyed blade block instead of splines.
I will eventually get pictures up!
Shayne
  • hamman and Sawdust have said thanks
#2 VTXrider ONLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted June 28, 2016 - 07:51 PM
Welcome to the forum Shayne.
The 50" mower deck comes in two flavors, short spindle and shorter. Both manuals are listed.
The spindles are not available to buy any longer. (but the bearings are). They do pop up on Ebay occasionally but go quickly. Not sure about changing to a keyed shaft and blade adapter but a machine shop could make them but it would be costly. (unless you have friends in the trade).
Some owners are lucky and find another deck for parts. Looking forward to seeing pictures.
  • boyscout862, Sawdust and MolonLabe have said thanks
#3 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted June 28, 2016 - 07:57 PM
Welcome to GTTalk ! Maybe someone here has at least one spindle to get you back mowing .
  • MolonLabe said thank you
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted June 28, 2016 - 10:06 PM
You can make your own spindle if you need too if you can't find one just need a pipe , round stock and a flat plate . And bearings. Those mtd parts are hard to find
  • Sawdust said thank you
#5 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted June 29, 2016 - 07:04 AM
I have 3 NOS spindles for the 992A deck
also 3 good used
I have the blade adapters as well as bearing holders
  • TheFarm2004, VTXrider, Sawdust and 1 other said thanks
#6 bbriggs OFFLINE
bbriggs
  • 1 posts
Posted July 03, 2017 - 06:44 PM
1oldbuzz do you still have any spindles for the 198-992a deck
