hydrostat problem
k71b
4 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted June 28, 2016 - 02:11 PM
I have a JD GT235 . The hydro whines when under a load aand quit's pulling in reverse under heavy load or incline . Sometime's jerky at low pedal force going forward on incline. Any suggestions.
larryd
#2 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,501 Thanks
  • 1,074 posts
Posted June 28, 2016 - 02:56 PM
  Doesn't cost much to change the tranny filter to see if it is the cause. Cut the old one apart to see how much metal is in it. That will tell you if the tranny has a very long future. Most filters work from the outside in but don't forget to look at the inside of the paper in case it's a reverse flow filter.
                                       Mike
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted June 29, 2016 - 11:29 AM
Hydro has an internal filter . Have to split case according  to JD.  K71B
Edited by larryd, June 29, 2016 - 11:33 AM.
#4 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted June 29, 2016 - 04:42 PM
Can you drain and flush it without a major issue?
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted June 29, 2016 - 06:33 PM
I done that with no change in effect.
