Caption This! 6-28-16
11 replies to this topic
#1 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,020 Thanks
  • 5,980 posts
Posted June 28, 2016 - 09:19 AM
:poke:  :wallbanging:  :hitting_self_roller:
  • Alc, hamman, boyscout862 and 3 others have said thanks
#2 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted June 28, 2016 - 09:30 AM
Ivan has an explosive fetish for metalworking.
  • jhn9840, Alc and boyscout862 have said thanks
#3 chieffan ONLINE
  • 10,901 Thanks
  • 6,923 posts
Posted June 28, 2016 - 10:13 AM
Testing for leaks but no soap bottle handy.
#4 pharmer ONLINE
pharmer
  • 881 Thanks
  • 780 posts
Posted June 28, 2016 - 10:14 AM
Billy Bobs first and last day on the job.
(This is the last known photo of him)
#5 oldedeeres ONLINE
oldedeeres
  • 10,294 Thanks
  • 5,024 posts
Posted June 28, 2016 - 10:26 AM
Nah, you don't need to watch the safety video, just get in there and weld.
  • Alc, jd.rasentrac and 29 Chev have said thanks
#6 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,988 Thanks
  • 3,233 posts
Posted June 28, 2016 - 10:31 AM
Once there was a chap named Bob
Who worked away quietly doing his job
Turning metal from this thing to that
Altering and changing its original shape of flat
He accomplished this using tools that could grind
As well as torches and other ones you would find
In a welding and fabrication shop
He worked every day sometimes non stop
Cutting and grinding and welding a bit
Then one day something got hit
With a shower of sparks from Bob's awesome work
Unfortunately fate added a slight little quirk
A leak of gas of the combustible style
Had formed a silent cloud that in a very short while
Ignited with a very loud thunderous boom
That shook the ground and filled the room
With lots of smoke and bits of debris
And Bob was no where that you could see
He had moved on to his new found occupation
As a singing welder at an angelic destination
  • Dane in PA, oldedeeres and Sawdust have said thanks
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,870 Thanks
  • 10,046 posts
Posted June 28, 2016 - 01:56 PM
Mythbusters? Nope, never watch it.
#8 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted June 28, 2016 - 03:03 PM
    As much as that is a stupid person rite there!!!!  I cant think of how many time I have seen and sometimes done that exact thing myself, I weld and fabricate for a living and sometimes there is just no good place for that set of torches especially when you are building big projects.  You do your best.
        Pete
#9 glgrumpy ONLINE
  • 8,722 Thanks
  • 7,977 posts
Posted June 28, 2016 - 05:32 PM
Thinking with thickness of tanks not an issue with that?  Small leaking around gauges maybe could go?  My worst problem with sparks is getting them to hit some projects I just cleaned up or even painted and it all stuck onto it.  Start Over!   I think if really a big issue, they would have a big slip over tank unit guard made by now, some Osha required thing, heh!!
#10 toppop52 OFFLINE
toppop52
  • 5,456 Thanks
  • 4,863 posts
Posted June 28, 2016 - 08:16 PM
Tanks Sparky! You're welcome...
#11 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 866 Thanks
  • 721 posts
Posted June 28, 2016 - 09:13 PM
Ummm don't see what everyone is talking about. Looks like normal to me.
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 29, 2016 - 08:39 AM
No leaks detected so far
