Anyone ever think about fabbing a new front axle?
8 replies to this topic
#1 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 381 Thanks
  • 419 posts
Posted June 27, 2016 - 05:23 PM
Bolens are sturdy. As all hell! That being said, the attatchment tabs on the front axle worry me. With it being cast, (Which I can't weld!), I am tempted to build a steep front axle so I can hang a Sears 2-stage snowblowet attachment off it. This will go on my H-16 with an 18 HP twin repower. Anyone else think of this? Am I nuts?
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 10226 Thanks
  • 5243 posts
Posted June 27, 2016 - 05:58 PM
I'd wait and worry about it after it breaks.  That way if it never breaks you won't be worrying for no reason.
Also,  its not a rare axle so a used replacement should be easy to find in the event you need one.
I've never seen one that had those tabs broken.  I used to have a G14 and ran a non-trip Wheel Horse blade on it.  I wound up breaking the entire cast iron nose assembly off the front of the tractors frame but those mounting tabs held.
#3 boyscout862 OFFLINE
  • 15260 Thanks
  • 10023 posts
Posted June 27, 2016 - 06:05 PM
When I got my H14 the bolts through the tubes were broken but everything else on the axle was okay. Four easing out and four new bolts and it was good to go. If it aint broke, don't fix it. Good Luck, Rick
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 27, 2016 - 06:16 PM
If used properly with OEM attachments there's no way those tabs are ever going to break. The only way you really break things on these machines is overloading them with things they were not designed to do.
#5 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted June 27, 2016 - 06:23 PM
Yes! Your are Nuts! :poke:
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 19089 Thanks
  • 11897 posts
Posted June 27, 2016 - 06:48 PM
Well, not completely nuts. If you just want a custom tubular axle to be kool, I can understand.
  • ClassicBolens said thank you
#7 farmerall OFFLINE
farmerall
  • 2260 Thanks
  • 1495 posts
Posted June 27, 2016 - 07:26 PM
I've only ever seen one of those tabs broken and the machine had a Haban sickle mower on it.
#8 JBRamsey OFFLINE
JBRamsey
  • 1642 Thanks
  • 911 posts
Posted June 27, 2016 - 08:38 PM
I need to get you an engineering flow chart. The first question is: is it broke? No? Leave it alone. Yes? Did you break it? Yes? Oh crap. No? No problem. Does anyone know you broke it? Yes? Oh crap? No? No problem.
#9 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 381 Thanks
  • 419 posts
Posted June 28, 2016 - 08:09 AM
Thanks for all the suggestions guys. My one worry was wanting to mount the 46" 2-stage blower I have on it, that's actually why I bought the tractor in the first place. (Yes I bought a tractor just to run a specific attatchment!) I most likely will end up making a bracket that loops over the frame, under the engine.
Sent from my SCH-R970 using Tapatalk
