Cub 123 hydro speeds up on its own.
6 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 27, 2016 - 05:13 PM
While mowing with my Cub 123 at a slow speed it wants to speed up by itself and I have to keep slowing it back down. How do I tighten the hydro lever up?
#2 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,328 Thanks
  • 4,954 posts
Posted June 27, 2016 - 05:45 PM
Under the tunnel [the sheet metal cover on the frame between the dash and seat] you'll see the bottom of the hydro lever has a white plastic bushing.  Been a few years but I think you need an Allen Wrench to tighten a collar around that bushing.  VERY small increments of tightening.  Don't try to cinch it down or the hydro lever won't move at all.
After you tighten it, if your adjustment doesn't last long, the bushing [believe its officially called a friction bushing] is worn out and needs replaced.
Edited by Gtractor, June 27, 2016 - 05:52 PM.
  • coinman66 said thank you
#3 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 27, 2016 - 07:16 PM
So do I have to take fenders off?
#4 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,328 Thanks
  • 4,954 posts
Posted June 28, 2016 - 02:08 AM
No.  You may access the part you need to get to with the fenders on.   Just 4 bolts/screws to remove the tunnel cover.
#5 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 28, 2016 - 01:22 PM
You mean 4 bolts to remove the tower? My Cub 123 has no removable tunnel cover like say a 1250?
#6 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted June 28, 2016 - 01:46 PM
If the decks off you should be able to get it from underneath.
#7 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 28, 2016 - 10:42 PM
Ok thanks for the tip Olds.
