Sear SS12 Carb Or Carb Kit
11 replies to this topic
#1 TinyTractorMan OFFLINE
TinyTractorMan
  • 2 Thanks
  • 5 posts
Posted June 26, 2016 - 12:46 PM
Hi guys, im new to the forum,And im having trouble finding a carb kit, none of my local stores have access to parts for these little guys, im in need of a carb or carb kit for a SS12 (unknown year) but it has a tecumseh 12hp engine, I need to rebuild the carb or just replace it, can anyone direct me to any online stores to find this item, the numbers on the engine are 143572012, I also have a ST12 with a very good mowing deck i will be working on soon, it runs and mows but needs a few small things before i sell it.IMG_0011.JPG IMG_0010.JPG
#2 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted June 26, 2016 - 01:24 PM
Hello Welcome to GTT :wave:
Most likely you have a walbro WHG or LME/LMH on there, I'll need your carb numbers that are stamped into it to direct you to the proper kit, I should have what your looking for instock
  • Tecumseh power said thank you
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted June 26, 2016 - 02:47 PM
Bolens 1000 has good carb kits I got them off him before the hh120 has an lme .
#4 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted June 26, 2016 - 03:35 PM
Often you could get the kit (or a replacement carb) going straight thru Walbro instead of thru Tecumseh, the one time I had to replace one of those carbs  thru Walbro it cost me like just over 1/2 of what Tecumseh wanted to charge for it. brand new, from the same small engine parts place.
  • 6mikey7 said thank you
#5 TinyTractorMan OFFLINE
TinyTractorMan
  • 2 Thanks
  • 5 posts
Posted June 27, 2016 - 05:36 PM
Thanks guys, ill get the numbers from the carb and post them, there is no wear on anything so i think the carb would be alright to rebuild, if it isnt been sitting too long, i did manage to get it to start, It just wouldnt idle or take throttle, i have an interested buyer in the st12 with the deck, whats the price point on them these days? I also have some equipment thats came with the ss that i will sell also, i use to get 100 a piece on it but not sure now. Thanks for all the help so far.
#6 TinyTractorMan OFFLINE
TinyTractorMan
  • 2 Thanks
  • 5 posts
Posted June 27, 2016 - 06:27 PM
The carb is a LME116 i also need the gasket for the clear plastic bowl on the "filter" will the kit come with it or will it need to be bought separate?
  • Bolens 1000 said thank you
#7 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted June 27, 2016 - 06:33 PM
Here's what you will need:
http://bolenspartsan...-free-shipping/
I assume your taking about the sediment bowl that mounts under the tank?
http://bolenspartsan...-692190-210468/
#8 TinyTractorMan OFFLINE
TinyTractorMan
  • 2 Thanks
  • 5 posts
Posted June 27, 2016 - 06:54 PM
yes but mine is mounted like this.
  • John Arsenault said thank you
#9 John Arsenault ONLINE
John Arsenault
  • 2,371 Thanks
  • 1,143 posts
Posted June 28, 2016 - 07:30 PM
I have one of these to its leaking and I want to fix it.....I'll start looking into it see who can find it first.....lol
#10 TinyTractorMan OFFLINE
TinyTractorMan
  • 2 Thanks
  • 5 posts
Posted June 29, 2016 - 11:52 PM
Bolens 1000 has the rebuild kits and the gaskets for the sediment bowl
#11 robj92 OFFLINE
robj92
  • 1 posts
Posted June 30, 2016 - 05:42 AM
May be interested in your implements if not too far away. Where are you located and what do you have?
#12 mcrile OFFLINE
mcrile
  • 4 Thanks
  • 7 posts
Posted July 09, 2016 - 10:27 PM
Check throttle shaft. wobble indicates worn shaft or housing. carbrescue.com
