Brinly 12" plow....finally got one
16 replies to this topic
#16 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted June 29, 2016 - 05:10 PM
When I mentioned building an adapter, I was assuming you were trying to convert it to sleeve hitch, not standard Cat-0 3-pt. If you are going for standard Cat-0, Old Buzzard has your answer. Even if the arms won't move in enough, you may be able to just make longer pins for where the lower arms attach.
Jim
Jim
#17 MH81 OFFLINE
Posted July 03, 2016 - 07:06 AM
Nice plow, just picked one up myself.
The Sears discs are light. There is a reason why 2 cement blocks fit on top of them...
If you build an adaptation, keep in mind that these were principally used behind 12-15 hp tractors. I have seen a lot of pretzels with Sears tags on them because someone decided their scut would pull them :D
