Brinly 12" plow....finally got one
16 replies to this topic
#1 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 25, 2016 - 09:12 PM
Picked this up and a small disc just 2 minutes down the road at a Mennonites place. Its a sleeve hitch but should work great still. It needs a Coulter. Can you still buy them? Also did these come with a depth wheel? Traded an old Sears stick welder for them.IMG_20160625_173353_357.jpg
  • olcowhand, MH81, Alc and 3 others have said thanks
#2 OldBuzzard ONLINE
OldBuzzard
  • 7,079 Thanks
  • 4,809 posts
Posted June 25, 2016 - 09:49 PM
:thumbs:  :thumbs: :thumbs:
Don't see those all that often.
The sleeve hitch plows are mostly 10".
Brinly still makes the sleeve hitch plow and parts are available:
http://shop.brinly.c...-Plow_c_26.html
Edited by OldBuzzard, June 25, 2016 - 09:54 PM.
  • ducky and JC 616 have said thanks
#3 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 25, 2016 - 10:07 PM
It has some white paint in places still so I'm assuming its an older one
#4 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 26, 2016 - 12:36 PM
Are the coulters the same between the 10" and 12"?
#5 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted June 26, 2016 - 01:01 PM
I think so!
  • JC 616 said thank you
#6 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 26, 2016 - 07:54 PM
Awesome. Now to get this 140 going Kenny. Also picked this up tooIMG_20160626_075935_912.jpg IMG_20160626_080005_111.jpg
Not sure what it fits or what brand but it has white paint on it too and on the arm looks like there used to be a tag riveted on
  • olcowhand, KennyP, michael.kitko and 1 other said thanks
#7 OldBuzzard ONLINE
OldBuzzard
  • 7,079 Thanks
  • 4,809 posts
Posted June 26, 2016 - 10:55 PM
That disc might be for the Sears 3-PT.
#8 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 27, 2016 - 03:31 AM
I should be able to make it work on my JD 140 still.
#9 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted June 27, 2016 - 05:04 AM
That disk looks Sears 3-point to me too!
#10 Alc ONLINE
  • 7,114 Thanks
  • 7,529 posts
Posted June 27, 2016 - 05:12 AM
Didn't Sears use it's own size width for the lower attachment points ?  Would that be able to say if it Sears or not ?
#11 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted June 27, 2016 - 05:30 AM
Yes they did. Around 12" apart.
#12 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted June 27, 2016 - 06:46 AM
I think so!
I have both plows here. A 10" sleeve and a 12" 3-point. According to the parts lists the coulter is the same. U-bolt may be different.
  • Alc and JC 616 have said thanks
#13 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 144 posts
Posted June 27, 2016 - 08:04 PM
Thanks Kenny. So would it be better to let a Sears guy have at this disc instead of fabbing it to make it work for me?
#14 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted June 28, 2016 - 05:40 PM
If I modify something like that, I try to make an adapter, that bolts to the implement, so It can easily be returned to original. I have a Brinly sleeve hitch cultivator that someone did the same for to use behind a 2 wheel tractor. I only had to remove one bolt to convert it back to sleeve hitch. As a bonus, if you built an adapter to make it work, the adapter would allow you to use other Sears 3 point implements as well.
Edited by CanadianHobbyFarmer, June 28, 2016 - 05:50 PM.
#15 OldBuzzard ONLINE
OldBuzzard
  • 7,079 Thanks
  • 4,809 posts
Posted June 28, 2016 - 08:17 PM
If you lift arms will go in far enough all you should be able to use it with a standard CAT 0 3-pt.
It will need the  CAT 0 lift pins in it though as they are missing.
  • CanadianHobbyFarmer said thank you
