simplicity 700 shifting issues
1 reply to this topic
#1 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted June 25, 2016 - 05:53 PM
I am in the process of putting my 700 back together after a tear down and paint. so I hooked up the shift rod and 1 & 3 are fine neutral is fine I can barely get it into 2nd and I can't get it into reverse. before the tear down I was able to shift.
any ideas? I peaked into the top fill and shifter is lining up ok with the forks.
#2 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted July 01, 2016 - 06:42 PM
If you spin the pulley on the transmission does the tractor move while in neutral?
Btw that top plug hole is not a "fill hole" the fill hole is at the bottom of the transmission at the street elbow on the lower right side.
Edited by skunkhome, July 01, 2016 - 06:45 PM.
