Wisconsin S-D12 problem
bolens 1250
8 replies to this topic
#1 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 25, 2016 - 11:45 AM
My problem is it floods out on high idle or under load. I've replaced the carb with a nos carb, change fuel filter and anything else I could think of that had to do with fuel. After all that it still flooded out so I took it to a "professional" small engine guy. He had it for several months which was fine, I didn't have to store it for the winter. Got it back yesterday, no charge, it's still doing the same thing. Any ideas???????? I'm lost. Jim
#2 chieffan OFFLINE
  • 16605 Thanks
  • 9090 posts
Posted June 25, 2016 - 01:08 PM
Hole in the float?  Float hanging up?  Just a couple things I have run into.  Good luck.
  • Eric said thank you
#3 boyscout862 OFFLINE
  • 15265 Thanks
  • 10024 posts
Posted June 25, 2016 - 01:24 PM
Since the usual seem to have been looked at, I'd suspect that the pump may be pushing too much pressure. Is a pressure release in the pump stuck? Good Luck, Rick
  • fogler12538 said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted June 25, 2016 - 01:37 PM
May be trash in the needle/seat
#5 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 25, 2016 - 01:44 PM
carb is all new (NOS)
#6 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 25, 2016 - 01:47 PM
When you first started after cooling down it idles fine, high and low. Once I move it or engage PTO it floods out
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted June 26, 2016 - 08:54 AM
How do you know it is "flooding out" and not an ignition failure?
Gas dripping from carb?  .....Sooty, black smoke from exhaust?
When it cuts out, is the sparkplug wet or dry?
Have you verified the presence of a strong spark right after the engine cuts out?
  • Bolens 1000, MailmAn and 29 Chev have said thanks
#8 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 26, 2016 - 09:30 AM
wet plug and it backfires when shut down
  • Bolens 1000 said thank you
#9 Bruce Dorsi ONLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted June 26, 2016 - 08:11 PM
I've heard of a lean mixture causing a backfire, but I've never heard of a backfire being caused by a too-rich mixture.
Backfiring through the carb is usually caused by an intake valve not seating properly, or improper ignition timing.
Backfiring through the exhaust is usually caused by an exhaust valve not seating properly or improper ignition timing.
The wet plug can be caused by flooding, or by faulty ignition (loss of spark).
Wisconsin engines are very sensitive to ignition timing, so setting points with feeler gauges is usually not good enough.
If you are losing spark, I'd start with a new condenser.  ....The points can be cleaned, reused, and reset unless pitted.
The best way to adjust the points is with a continuity tester or test light to get the timing correct.
  • Bolens 1000, LPBolens, MailmAn and 2 others have said thanks
Also tagged with one or more of these keywords: bolens 1250
