HF compressor question
10 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 24, 2016 - 05:03 PM
I do not have a way to check this myself, at least not here in the shop.
The drain valve is such that I have to lift the end in order to drain moisture from tank and I would rather put in an adapter and 90 so a short piece can be run out to a ball valve.
Anyone know the thread size, metric, or, whatever, on HF compressors drain valves?
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,998 Thanks
  • 5,972 posts
Posted June 24, 2016 - 05:21 PM
It's most likely 1/4" NPT.  I remove the butterfly valve and install a 90° ell which will connect to a 1/8" copper tube..  Then I install a ball valve @ knee to waist high and direct the pipe into a bucket to catch the water..  It works great..
  • olcowhand, Lmiller3358, HDWildBill and 3 others have said thanks
#3 olcowhand ONLINE
  • 42,301 Thanks
  • 31,772 posts
Posted June 24, 2016 - 07:15 PM
I agree, likely 1/4" NPT.  That reminds me....I need to drain the air compressor at work, and clean it's check valve.
  • MH81 and Phluphy have said thanks
#4 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 24, 2016 - 08:55 PM
Thanks for the replies. Have several 1/4  NPT fittings etc. Figured since it was made on the other side, it was more than likely metric and didn't want to risk buggering the threads if I made the wrong decision.
Will pull the fitting tomorrow and see if there's a match. If not...taxi time.
#5 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 24, 2016 - 09:55 PM
Rats...Took a 14 mm socket to get it out so thinking it's metric. Off to Ace, hoping they have metric fittings. But then, the other day not one person in the store knew what a shackle was...until I literally drew them a picture and that wasn't so easy with these fumbling hands.  Will make a call first on the fitting situation.
Thanks for the responses.
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted June 24, 2016 - 10:14 PM
  Most everyone likes to call a shackle a clevis. An old crane operator years ago explained to me that farmers use clevises, iron workers use shackles. A farmer puts a cotter pin in a clevis pin and plows for years with it. An iron worker screws a shackle pin in just snug and then backs it off 1/8 of a turn. If you don't back it off then after a hard lift you're reaching for the crescent wrench to get it loose. If you must use a shackle to drag things over the ground then you use that crescent wrench to tighten the pin down so you don't find yourself looking for that pin that unscrewed itself. All my working life I used far more shackles than clevises!!
                                                Mike
  • MH81, Alc, boyscout862 and 1 other said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted June 24, 2016 - 10:17 PM
 If it is 1/4" NPT try to find a brass street ell. It will protrude less than a common street ell.
                                        Mike
  • MH81, boyscout862 and Phluphy have said thanks
#8 JBRamsey OFFLINE
JBRamsey
  • 1,541 Thanks
  • 869 posts
Posted June 24, 2016 - 11:01 PM
NAPA should have them.
#9 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 24, 2016 - 11:12 PM
                                        Mike
I have street L's and right you are about how they take less space, and, no dice on the NPT. Wrong thread.
#10 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 24, 2016 - 11:17 PM
                                                Mike
I move several heavy logs with the log mover, shackles are all I know. I've always considered mechanical connections i.e. actuating arms etc. to operating rods to be clevis connections. Eh, "tomato-tomahto" depends where, and how. Thanks
  • MH81, Alc and ol' stonebreaker have said thanks
#11 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,484 Thanks
  • 6,178 posts
Posted June 25, 2016 - 10:15 AM
Shackle, or screw pin shackle
Clevis, I've more commonly heard these as a wire rope clip/clamp.
That's what I consider the two, but working in the coal mines, we have different names for some stuff.
My favorite, this wire roper gripper is known as a "pork chop"
Also hose clamps are always "breeze bands"
Edited by toomanytoys84, June 25, 2016 - 10:17 AM.
  • WNYTractorTinkerer and Phluphy have said thanks
