30 Second H-16 Repower.....Seriously!
4 replies to this topic
#1 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 381 Thanks
  • 419 posts
Posted June 23, 2016 - 09:30 PM
Well, lesson learned. Any 14-20 HP Briggs Vanguard V-Twin fits in place of the Tecumseh's in the H-16 definitely, and most likely the H-14 and G-10/11/12/14 etc. All the bolts are the same pattern, size, and the original spacers work too! Only issue is the Vanguard had a 1" shaft, where the Techy has a 1 1/8. Also, no more scoop hood! Regular hood fits, I used a straight 850 hood I had. I may also change the fenders to 850 ones, and just weld a cover plate on them. Also converting this thing to a 15 spline, 1" PTO. Motor and PTO are off a White GT-1855!1056c04ba3b6ccacdfef4c94c605c0b2.jpguploadfromtaptalk1466735445308.jpg uploadfromtaptalk1466735452262.jpg
Edited by Diesel1050, June 23, 2016 - 09:31 PM.
  • LPBolens, blackjackjakexxix, Sawdust and 1 other said thanks
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1534 Thanks
  • 1133 posts
Posted June 23, 2016 - 10:29 PM
Did you use a bushing on the crank for the pulleys
#3 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 381 Thanks
  • 419 posts
Posted June 23, 2016 - 10:42 PM
Yes, a 1 to 1-1/8 adapter
Sent from my SCH-R970 using Tapatalk
  • Sawdust said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4256 Thanks
  • 5840 posts
Posted June 24, 2016 - 06:53 AM
Good to know. I have one of engines sitting on the floor
#5 Husky OFFLINE
Husky
  • 1508 Thanks
  • 1202 posts
Posted June 25, 2016 - 08:49 AM
Nice job on that. I used an adapter on the shaft of the 18HP L Head engine when I did built my 1856 tube frame tractor. You will enjoy that tractor with the V twin in it.
