TECUMSEH HH120 CARB
8 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted June 23, 2016 - 04:27 PM
i have a sears hydro trac super 12 that needs a carb. it had a walboro on it.on the carb it says lme, above that #27. on the other side it has #68. what one is the carb number? and does anyone know where i can find a used one
#2 MNGB OFFLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted June 23, 2016 - 05:05 PM
Do you have a carb or not? They come up on ebay pretty regular but most need rebuild basically any LME carb will work.
  • Xrperry said thank you
#3 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted June 23, 2016 - 07:01 PM
sorry i do have the carb, and it is junk.
#4 MNGB OFFLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted June 23, 2016 - 07:12 PM
Hi Xrperry, you might want to check with Mark Hare at carb rescue he dose excellent work and has brought many near death carbs back to life
http://www.carbrescue.com/intro.html
  • Sawdust, 6mikey7 and Xrperry have said thanks
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 23, 2016 - 08:09 PM
A Tecumseh series 4 carb will bolt right on. They are easy to find and the hh120 came with them too. They came with either or. If you use a Tecumseh carb you need a spacer so the float bowl doesn't hit the case breather. You can get them on ebay for 8 dollars or make one. What is wrong with yours?
Edited by Tecumseh power, June 23, 2016 - 08:09 PM.
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 23, 2016 - 08:12 PM
Here is the numbers and applications for the number in the side of the lme
  • Xrperry and John Arsenault have said thanks
#7 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted June 23, 2016 - 08:41 PM
thanks tecumseh power, the carb looks like acid sat in it. inards including float ate up.
  • Tecumseh power said thank you
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 23, 2016 - 10:00 PM
I'd like to see a pic of it ,it may still be good. I have seen them pretty ate up but all the things that counted in them were still good. You can get a new float and jets
#9 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted June 24, 2016 - 09:33 AM
I will be looking for a couple of these.
