Tips needed on applying new decals
14 replies to this topic
#1 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted June 23, 2016 - 02:01 PM
OK all, I just received an expensive decal set, and no application instructions. I assume just peal and stick, but I would like to get some suggestions for the large ones on how to apply them straight with no crinkles.
  • Sawdust and 637Yeoman have said thanks
#2 Bill 76 ONLINE
Bill 76
  • 1,947 Thanks
  • 1,196 posts
Posted June 23, 2016 - 02:16 PM
I don't know if it will work with your decals but when I used to put vinyl lettering  on race cars the only way to do it was to spray sticky side and the car with water or window cleaner and work out the bubbles with a bondo spreader ---the water will let you move them around
You don't need much , just a light mist on both surfaces--after the water dry's they are on for good.
Someone else may have a better way , but I haven't found it.
  • larrybl, Alc, hamman and 4 others have said thanks
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted June 23, 2016 - 02:19 PM
That's the same way I do them. The Bo do spreader works as a squeegee to remove the bubbles
  • larrybl, hamman and SamMC have said thanks
#4 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,763 Thanks
  • 2,884 posts
Posted June 23, 2016 - 02:29 PM
My limited experience is to use the "wet" method on a surface coated with a mixture of dishwasher detergent and clean water after you make sure the surface is clean.  I would suggest doing a smaller one first and see what success you have.  I use masking tape on the top edge to position and secure the decal initially, once it is positioned where I want it I flip it up and carefully peel the back off the decal, spray or apply the soapy water mix with a sponge or clean cloth onto the back of the decal and also on the area where it will be attached.  Then flip the decal back down and use a plastic squeegee such as a body filler applicator and starting at the top and centre work the soapy water and any air bubbles out from underneath the decal by working towards the ends and slowly work your way towards the bottom of the decal.  You can check out clickitandstcikit's instructions here - http://www.clickitan...n-instructions/ .  Make sure you are working in a warm but not hot area - do not apply them in direct sunlight as the liquid will evaporate too quickly .  You can check out the one set that I did on a Bolens here http://www.mytractor...together-8.html starting at post 107 as it shows how I did the front decal using the masking tape.  I applied it dry and had a couple of air bubbles which is why I switched to the "wet" method.  Hope this helps and good luck.
  • larrybl, Alc, hamman and 5 others have said thanks
#5 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Posted June 23, 2016 - 03:31 PM
I've done a few on Speedex. I had no luck with wet, but might just be my method. I do dry, sometimes line or tape to make it line up. Many decals have split full length and you can open just the top of letters, or bottom and roll down to stick, then fold back top or bottom that is left, tear off the backing and roll it back on carefully.  My MM tractors show wet method in istructions or the dry also. One thing for sure is to have the surface clean and no water spots, best to wipe off with towels after washing, let dry. I've held up the decal, taped whole thing up after eyeing it in place and done one end to start, then from middle where first pull ended, roll the backing out from under it as you push on decal to stick straight to surface.  Dry way does not offer any fixes if not straight, but I have been lucky I guess!  Many decals made from vinyl layers are placed on tractor with all the papers still on the front face, then slowly remove backing, stick to surface, then again slowly and while pressing as you go, pull off the outer papers, the vinyl stays behind. That is the plan at least.
  • larrybl, Alc, Sawdust and 1 other said thanks
#6 chieffan OFFLINE
  • 10,194 Thanks
  • 6,657 posts
Posted June 23, 2016 - 03:35 PM
Some decals don't like the soapy water method as it removes the adhesive.  Check with the decal company and see what they tell you.
  • larrybl, Alc, hamman and 1 other said thanks
#7 HANKG OFFLINE
HANKG
  • 6,323 Thanks
  • 3,427 posts
Posted June 23, 2016 - 05:36 PM
I Like to have at least two shots first to calm the nerves then I eyeball them and go, so far so good.
  • larrybl, limebuzz, Alc and 3 others have said thanks
#8 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted June 23, 2016 - 05:48 PM
If they are stickers u should be able to use windex mixed 1/2 with soapy water. I have a cloth tape and make numerous dots for reference with a grease pencil (it comes off easier). then I make sure I have no distractions (wife and kids) and then follow hanks steps
  • larrybl, HANKG, Sawdust and 1 other said thanks
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted June 23, 2016 - 06:26 PM
Well, this make sense! And also " then I make sure I have no distractions (wife and kids) and then follow hanks steps". I'll check the site where I got them and mock everything up this evening.
  • HANKG said thank you
#10 olcowhand ONLINE
  • 41,262 Thanks
  • 31,447 posts
Posted June 23, 2016 - 06:32 PM
2 or 3 drops of dishwashing liquid in a cup of water will work fine.  Best way is the wet method.  Doing them dry allows for NO errors at all!
  • larrybl and Sawdust have said thanks
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted June 23, 2016 - 09:49 PM
On BOH decals, I checked site for instructions http://www.clickitan...n-instructions/ I set the decals accordingly and think I'll use the dry method on the small decals. Still on the fence with the wet method. Biggest comments were Calm, no distractions, and slow and easy.
So I am taking tomorrow off from work, and leave the phone in the house, TV will be off. and try the dry method. I did one just to see what is involved.
  • Alc, KennyP and 29 Chev have said thanks
#12 jpswift1 ONLINE
jpswift1
  • 642 Thanks
  • 541 posts
Posted June 24, 2016 - 12:23 AM
Nice Craftsman tractor!  I've done some research and I've found a very good option for applying decals.  This stuff:
https://www.amazon.c...customerReviews
I've got lots of tractors and motorcycles that I'm going to be applying decals to and I plan on using this because of all the excellent reviews.
  • larrybl and KennyP have said thanks
#13 Kster526 OFFLINE
Kster526
  • 845 Thanks
  • 561 posts
Posted March 07, 2017 - 05:34 PM
Window cleaner/windex with the a softer bondo scraped as everyone has said is my
preferred method. One thing to do first is use some blue masking tape and mark it out.
With the window cleaner behind it it allows you time to get it just right and won't peel off
fresh paint if you do not have it positioned right. I keep a micro fiber rag with me and lightly
dab the sticker before running squeegee over it plus you do not always need a
squeegee why take a chance ruining the best part of the project. The finishing touch
#14 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted March 07, 2017 - 07:46 PM
Oops for got to post the final pictures. Windex and a rubber spatula worked a treat! Been doing great, lots of looks!
  • KennyP, backwoods, EricR and 3 others have said thanks
#15 Kster526 OFFLINE
Kster526
  • 845 Thanks
  • 561 posts
Posted March 08, 2017 - 02:27 AM
Looks good
