Question
7 replies to this topic
#1 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted June 23, 2016 - 10:28 AM
What is the distance, pin to pin of the 3pt. Horizontal lift arm for the long hood metal tractors with the arm running above the frame. It appears to be straight with no bends. Correct? Thank you.
#2 MNGB ONLINE
MNGB
  • 1,187 Thanks
  • 922 posts
Posted June 23, 2016 - 11:52 AM
Hi, if I'm understanding the question your asking about the lift rod from the hyd cylinder arm to the 3 pt lift arm?  If so it is 3/4" OD X 34.5" long with 8 adjustment (1/4") at the 3 pt end and 2   7/17" forward holes and yes it is straight.
#3 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted June 23, 2016 - 03:01 PM
Yes it is and thank you very much.
#4 MNGB ONLINE
MNGB
  • 1,187 Thanks
  • 922 posts
Posted June 23, 2016 - 03:23 PM
Do you have any of the parts? There is a square block with a 3/4" hole that goes over the rod, it has a 7/16" cross drilled hold for a pin to the 3 pt lift arm and then there are 2 1/8" hair pins a 3/4" washer and a 6" spring with 3/4"ID.
#5 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted June 23, 2016 - 03:32 PM
I got nothing. Thought I might mount a pin on the arm connected to the cylinder then slot the lift arm. Like the ingersoll sleeve hitches. Is this a bad idea?
Edited by BowlBuilder, June 23, 2016 - 03:33 PM.
#6 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted June 23, 2016 - 03:34 PM
At rest, what do the connecting pins measure center to center?
#7 MNGB ONLINE
MNGB
  • 1,187 Thanks
  • 922 posts
Posted June 23, 2016 - 04:01 PM
Can't tell you that right off they are adjustable if I go into the shop tomorrow I'l try to remember to measure heres some pictures of the hardware it can be made with a drill press and some time. The block is about 1"X1.5"x1.5"
#8 BowlBuilder OFFLINE
BowlBuilder
  • 448 Thanks
  • 430 posts
Posted June 24, 2016 - 05:37 PM
I believe I've got it. Thank you gentlemen for your helpful information.
