Simplicity Baron S soveregin
4 replies to this topic
#1 bolensqt17 OFFLINE
bolensqt17
  • 27 Thanks
  • 21 posts
Posted June 22, 2016 - 10:09 AM
Hello... I just purchaced a Simplicity Baron S. Trying to figure out what size Briggs Motor is on the tractor because it needs rings but I need to know where to start. It's all original and the only numbers I can find on the Tractor is the id tag which says 979-5541. Any help would be appreciated. Thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,270 Thanks
  • 10,114 posts
Posted June 22, 2016 - 11:09 AM
The model # of the Briggs should be stamped into the shroud, left side as seated.
  • bolensqt17 said thank you
#3 case442 ONLINE
case442
  • 694 Thanks
  • 424 posts
Posted June 22, 2016 - 03:36 PM
Hello,
My baron is a 7013 s which has the 13 hp Briggs/Stratton
Mike
#4 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted June 22, 2016 - 05:08 PM
Info from Simplicity Repair Manual
Edited by drbish, June 22, 2016 - 05:09 PM.
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted July 01, 2016 - 08:37 PM
The full manufacturing number of your tractor is 990979 and the serial number is 5541. They were made in 1974 only. My favorite tractor. http://bsintek.basco...wf5kbp796Dq.pdf
I have the original engine out of mine and I had no success trying to find new rings. I finally relented and ended up repowering with a 16 hp Briggs. It's is an awesome tractor and I really like the shuttle. The manual has the proper adjustment for the shuttle mechanism. Follow it to the letter and you will really enjoy the drivetrain.
Edited by skunkhome, July 01, 2016 - 08:55 PM.
