Correct Mower blade angle .......
9 replies to this topic
#1 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,439 Thanks
  • 2,861 posts
Posted June 22, 2016 - 08:59 AM
I've heard anything from 30, 35, 40 45 to 60 degrees of angle when sharpening. What do you guys sharpen at? I've always stayed with the factory angle, sadly I've never gauged it to see what it was. I have a lot of people around the area that want me to sharpen their blades and was thinking about making a dedicated jig for the grinder just for mower blades. I know they are cheaper now days but a lot of people want theirs sharpened a couple of times if possible. Now we live in a area of Michigan that is very sandy and that reeks havoc on the blades. Just wondering what is out there on angles. I've seen guys use a angle grinder to do it with flap discs, a belt sander with 120 grit and the smaller HF belt sander to do it. Thanks for any info. Now out to mow a couple acres and then to sharpen some blades. About 20 that have been dropped off and sent to me.    have a great day!        Roger
  • propane1 said thank you
#2 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted June 22, 2016 - 09:04 AM
​I do a lot of blades myself but most time just replace with new. The angle to use is 30 degrees as that is what most of the new ones I have here are. Hope that helps
  • Alc and hamman have said thanks
#3 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,132 posts
Posted June 22, 2016 - 11:45 AM
That's what I was thinking. 30 degrees. You've got a busy day ahead of you Roger. I just finished cutting two and half acres, with my 1951 Ferguson tractor and 6' finish mower.
Noel
  • hamman said thank you
#4 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,927 Thanks
  • 5,976 posts
Posted June 22, 2016 - 11:57 AM
People really buy new blades when theirs get dulled down?  I don't think I have ever seen anyone in my family buy new blades.  Dad usually pulls them off twice a summer and sharpens them on the grinder, and back on the mower they go.  All I ever seen him do, or done myself is match what was already there
  • hamman and shorty have said thanks
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,989 Thanks
  • 10,009 posts
Posted June 22, 2016 - 12:14 PM
Don't have sandy soil, do ya? Be lucky to get two seasons out of a set of blades around here. They kinda get sandblasted while they're cutting.
  • hamman and chieffan have said thanks
#6 shorty ONLINE
shorty
  • 5,500 Thanks
  • 5,267 posts
Posted June 22, 2016 - 12:30 PM
I just try to match the factory angle. The main mower has the same set 8+ years. The back up mower has blades 18 years now. They get touched up every few years. More of a rough cut mower mainly for the neighbor.
  • hamman, toomanytoys84 and Bill 76 have said thanks
#7 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,585 Thanks
  • 968 posts
Posted June 22, 2016 - 03:38 PM
Yup 30 degrees seems most common, pattern after one of these perhaps, it's what I did, just make the blade bed a little longer it will maintain contact and help it stay true all the way to the edge
I like 60 grit flap discs on a 4-1/2" grinder with a maintained on/off switch.
https://www.bing.com...b6o0&ajaxhist=0
#8 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted June 22, 2016 - 03:42 PM
if the blades just need a touch up I use a 12" file and match the angle that is there.
If the blade need more than a touch up I use and angle grinder and try to might the angle of the blade.
#9 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Supposed to sharpen blades??  Once a year, usually in spring here. Just take to local shop. For the few bucks they ask, they get dirty, wear out equip. They just grind about same as orig I guess. I don't think it really makes much diff, some sort of sharp edge at those speeds is gonna cut grass. If you really look at new ones, they are Not all that sharp, just nice and even really. I think the bent up part just behind the cut edge is where you get the most changes in the lift and seperating actions and how it wind-rows on the lawn.
#10 hamman ONLINE
hamman
  • 6,439 Thanks
  • 2,861 posts
Posted June 22, 2016 - 07:10 PM
Thanks guys. Been looking a lot after the first post and it looks like 30* is it. Now I just thave to make a jig to fit to the grinder. Saw a coulpe of ideas on youtube but I will have to modify for my needs. Thanks again. Back out to mow again until dark. Another neightbor needs his summer place taken care of before this weekend. Think I'm going to have to look for a newer machine to mow with. Just don't like using the old ones for all that mowing.                                                  Roger
  • WNYTractorTinkerer and propane1 have said thanks
