Wanted
Kohler 18hp Twin
5 replies to this topic
#1 chieffan ONLINE
  • 10,128 Thanks
  • 6,631 posts
Posted June 22, 2016 - 07:11 AM
Should be Kohler.  Stiff fingers are not working good this morning.
Looking for a running Kohler twin for my 1811.  Could probably make a Briggs work but would have to be complete.  Either one has to be horizontal crank for shaft drive tractor.  Picked up a real nice 1811 for the rear end and found I don't need it.
Edited by chieffan, June 22, 2016 - 07:13 AM.
#2 KennyP ONLINE
  • 38,296 Thanks
  • 45,894 posts
Posted June 22, 2016 - 07:30 AM
Fixed the title for you! Good luck!
  • chieffan said thank you
#3 glgrumpy OFFLINE
  • 8,606 Thanks
  • 7,913 posts
Posted June 22, 2016 - 03:50 PM
Swap meets this summer! I find most times cheaper and easier to find complete donor tractors to get ALL the little stuff needed for a swap. Just for me, what is an 1811?  Brand? Worth fixing?
#4 chieffan ONLINE
  • 10,128 Thanks
  • 6,631 posts
Posted June 22, 2016 - 05:39 PM
No swap meets around here with 150 miles that I have ever heard of so that idea is out.   An 1811 is a Cub Cadet GT, in real nice shape and well worth putting a motor in.  NOT a big box store lawn mower - 44" deck, Sunstrand Hydro  has the side covers with it.
#5 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted June 29, 2016 - 07:17 AM
I have a M18 I would part with
Should run
It needed a ignition module which I replaced at a cost of $125
and needs 1 magnet in the flywheel reglued
It has 20 pounds oil pressure cranking with the starter
I paid $250 not including the module
will part with it
for $275
located in Manitowoc WI 54220
#6 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted July 01, 2016 - 07:05 PM
Some sears had the Kohler M18 in them. I would go with the kohler. I just took a M18 from a 1811 and put it in a 782.
Also tagged with one or more of these keywords: Wanted
