Carb cleaner, picture.
17 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted June 21, 2016 - 03:44 PM
What do you think? Taped a engraver to the plastic container, turned to number 5 and turned it on.
Noel
  • Gtractor, lyall, KennyP and 6 others have said thanks
#2 James Bosma OFFLINE
James Bosma
  • 1,478 Thanks
  • 729 posts
Posted June 21, 2016 - 03:51 PM
Should vibrate it pretty good
Have to love how ultrasonic cleans
  • propane1 said thank you
#3 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted June 21, 2016 - 03:53 PM
I like it what cleaning solution are you going to use
#4 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted June 21, 2016 - 04:01 PM
Dish soap , spray nine and water. Hot water out of kitchen tap. Not much soap or spray nine.
Noel
#5 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 21, 2016 - 04:08 PM
Hey, if it works, why not!
#6 glgrumpy ONLINE
  • 8,803 Thanks
  • 8,014 posts
Posted June 21, 2016 - 04:24 PM
Does it stay on the bench or want to walk?? Too fine for that?  Water and soap?  That really do much?  Heck, if Laq thinner don't cut it, don't see where soapy stuff would do much. I even blast sometimes, but has to be bad and watch for grit in tight places then too.
  • Eric and propane1 have said thanks
#7 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted June 21, 2016 - 04:39 PM
Stays put gl, no walking. Just testing. May use real carb cleaner mixture next time.
Noel
Edited by propane1, June 21, 2016 - 04:41 PM.
#8 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted June 21, 2016 - 04:59 PM
Some dirt came out of the weed whacker carb.
Noel.
#9 Mtypython OFFLINE
Mtypython
  • 371 Thanks
  • 350 posts
Posted June 21, 2016 - 05:20 PM
Nice idea,economical
#10 KC9KAS ONLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted June 21, 2016 - 06:28 PM
I bungeed a sander to my sand blast pot to keep the media worked down.
I was a good idea, but it didn't work!
  • Alc and propane1 have said thanks
#11 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,855 Thanks
  • 6,346 posts
Posted June 21, 2016 - 07:08 PM
I bought a small ultrasonic cleaner at a flea market a few years ago. Just big enough to fit your average carb in. Works pretty good.
That seems like that would work pretty good. Was the dirt inside the carb or on the outside?
#12 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted June 21, 2016 - 07:25 PM
Both, outside and in. I hope the carb works when I put it together tomorrow. Fourth time I've had the carb apart. I don't like small 2 stroke engines. Most shops around here won't even work on them.
Noel
#13 boyscout862 ONLINE
  • 13,548 Thanks
  • 9,427 posts
Posted June 21, 2016 - 08:57 PM
Another Red Green fan!
  • Titus and propane1 have said thanks
#14 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted June 21, 2016 - 10:29 PM
Noel
I don't at my shop they get replaced.
#15 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted June 21, 2016 - 10:53 PM
  I had a couple of gorounds w/ my Echo weedeater carb. Cleaned it once, kitted it the 2nd time and installed a new carb the third time. It was a dump rescue so even w/ the new carb I'm still money ahead.
                                    Mike
