Hibernating Kohler K160
15 replies to this topic
#1 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted June 20, 2016 - 07:57 PM
I have a Bolens Versamatic with a Kohler K160 that I got running a few years ago. But last year when I pulled it out of the shed, it wouldn't even try and fire. I've tried all the things I could think of. I took the points apart and cleaned the contacts, gapped them to 0.020, cleaned out the carb, tried different spark plugs in it, cleaned up the ignition system, re- sealed the head gasket,etc. I can get it to pop once or twice on occasion but can't get it to stay running. I would really appreciate some advice. Thanks in advance.
#2 Trav1s ONLINE
Trav1s
  • 3,198 Thanks
  • 4,299 posts
Posted June 20, 2016 - 08:00 PM
Do you have a valve stuck open?
#3 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted June 20, 2016 - 08:22 PM
I don't think so. When I had the head off, both valves where moving when I spun the flywheel, and the timing was also correct. Which is good, but it still wouldn't run,haha!
#4 Trav1s ONLINE
Trav1s
  • 3,198 Thanks
  • 4,299 posts
Posted June 20, 2016 - 08:38 PM
How strong is the spark?  Is that a magneto design?
#5 jimbobbillyray ONLINE
jimbobbillyray
  • 2,800 Thanks
  • 2,763 posts
Posted June 20, 2016 - 08:41 PM
Try changing the condenser. They will do that when they go bad
#6 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted June 20, 2016 - 08:46 PM
It uses one of those Bendix magneto coils with points and a condensor. The coil was fairly rough when I bought the tractor, but I was able to make it work by coating it in liquid electrical tape. The spark is fairly good, enough to fire the engine, I think.
#7 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted June 20, 2016 - 08:49 PM
I thought about the condenser being a possibility, I'm just not sure where to get one that will work on that motor.
#8 boyscout862 ONLINE
  • 12,569 Thanks
  • 9,048 posts
Posted June 20, 2016 - 11:41 PM
Download the engine manual from our Manuals Section and follow the troubleshooting guide. A good spark in normal atmosphere may not work in a compressed gas. I have an old B&S tool that creates a pressure to test the plug in. Check your grounds too. Good Luck, Rick
Edited by boyscout862, June 20, 2016 - 11:43 PM.
  • MolonLabe and AllisKidD21 have said thanks
#9 Bolens 1000 ONLINE
  • 14,926 Thanks
  • 18,112 posts
Posted June 21, 2016 - 08:14 AM
I would check your Condenser and ignition coil again, these bendix have started to fail the last 3-4 years it seems as I have been getting alot of requests for coils on them
If you need anything send me a PM I have all the parts instock for this engine's ignition system
  • jimbobbillyray, boyscout862 and AllisKidD21 have said thanks
#10 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted June 21, 2016 - 08:46 AM
Any chance you can post a pic of it, Rick ?
#11 boyscout862 ONLINE
  • 12,569 Thanks
  • 9,048 posts
Posted June 21, 2016 - 09:19 AM
I'll try to find it today. It is a neat little clear plastic tube set. It is shown in the B&S Repairmans' Manual. Good Luck, Rick
  • Bruce Dorsi said thank you
#12 boyscout862 ONLINE
  • 12,569 Thanks
  • 9,048 posts
Posted June 21, 2016 - 08:35 PM
I did some digging and found it, still in its original box. Eleven years ago I bought out the leftover stock from a local Bolens dealer. He had sold the modern stuff and nobody wanted the old stuff. Since I did such a nice job cleaning up his shop he threw in a bunch of manuals and dealer tools. I hope that my pics are clear.
The last pic shows the pressure pumped up. A really slick little tool. Good Luck, Rick
  • Bolens 1000 and Bruce Dorsi have said thanks
#13 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted July 05, 2016 - 11:37 AM
Thanks to everyone for the advice, I'm going to go buy a new condenser and see what happens. I'll keep you all posted!
#14 AllisKidD21 OFFLINE
AllisKidD21
  • 7 Thanks
  • 14 posts
Posted July 16, 2016 - 09:12 PM
Well, I purchased and installed a new condenser on the the ol' Kohler. It worked somewhat for a little while, but she is back to having no spark at all. I suspect the coil is bad, but I think a new one is around $80(OUCH!) Any other suggestions would be greatly appreciated.
#15 Bolens 1000 ONLINE
  • 14,926 Thanks
  • 18,112 posts
Posted July 16, 2016 - 09:15 PM
I have them in stock if needed seems like alot are kicking the bucket these past couple years
http://bolenspartsan...products.search
