Calling ALL Hydraulics Guru's!
189 replies to this topic
#106 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted November 22, 2016 - 05:44 PM
I sourced the orings you need. This will do a complete 2 spool Valve including the spool seals Pt# 206.
Anybody want a set let me know.
$5.00 US free Shipping.
Can do Pay Pal.
Don, please PM me your paypal address.  I'll take one set please.
  • ducky and KennyP have said thanks
#107 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 22, 2016 - 07:44 PM
For the 15th time, pic upload failed!
#108 dropped82 ONLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,905 posts
Posted November 22, 2016 - 08:37 PM
Can do Pay Pal.
Count me in please.
Oh and anyone know what Wheel horse models use these valves?
Eric
Edited by dropped82, November 22, 2016 - 09:02 PM.
#109 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 23, 2016 - 01:30 AM
Dan you are on. Give me a bit as I forgot the oring for the relief valve. Same price I just want you guys to have everything.
  • olcowhand said thank you
#110 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 23, 2016 - 01:31 AM
test pic
#111 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 23, 2016 - 01:32 AM
Count me in please.
Eric
I think this will cover it.
Attached File  OMCO Valve Repair Procedure.pdf   1.52MB   22 downloads
If you need more info just post.
Edited by ducky, November 23, 2016 - 01:41 AM.
  • KennyP, dropped82 and TomLGT195 have said thanks
#112 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 23, 2016 - 01:47 AM
I did not get out to the shop tonight so bear with me guys till we get those relief valve rings.
#113 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 05:52 AM
Finally got one pic to upload using the basic uploader. This is where I started taking the valve apart.
This is what i found inside.
The two spool sections are steel, so an air angle grinder with a scotchbrite pad will clean those. I'll have to be real careful with the ends sections as they are aluminum.
  • Alc and SupplySergeant have said thanks
#114 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted November 23, 2016 - 06:41 AM
Doesn't look like there would be anything in there which would cause your deadhead problems . Maybe after you put the new seals in it and before installing it you could hook up your shop air with a regulator and air test it like you would do a automatic transmission , both spools , that one has a float function doesn't it ?
#115 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 07:16 AM
Not sure if I could do that test with air, not nearly the pressure the hydro has. This valve was leaking at the rear of the spool plus between the valves. I attribute most of that to old o-rings and the rust between the valves. The o-rings between are real stiff.
Don, make me up a set of those. I have 2 more of this type valve on the FF's. When I got most of the o-rings here, I picked up an extra of each that I got. Not sure how long before they can get the metric ones.
#116 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 07:32 AM
I'll get out this morning and get some pics into the valves to show how the spools are sitting for return flow when centered, Don. Then start cleaning.
#117 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted November 23, 2016 - 08:33 AM
Kenny , my thought with the air was not to test for leaks but to see the flow through  the valve when the spools where moved
#118 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 09:04 AM
Okay!
#119 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 02:39 PM
Got them cleaned up and new seals/o-rings installed. Ready to go back together when I get the last 4 o-rings. Got a ton of pics, but gotta upload one at a time. For some reason, the advanced uploader isn't working. I remembered I had a good razor blade scraper and used that instead of the scotch-brite disk. Worked real well!
  • olcowhand, Alc, TomLGT195 and 1 other said thanks
#120 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted November 23, 2016 - 04:29 PM
Testing the advanced uploader! Looks like uninstalling FF and reinstalling did the trick.
  • olcowhand and Alc have said thanks
