Calling ALL Hydraulics Guru's!
189 replies to this topic
#61 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 19, 2016 - 05:59 PM
I just went to Surplus Center and read more on this filter. It is a 200 PSI max return line filter (with 18 PSI relief). So that may be the whole problem.
Here is a screenshot from the Ford Manual.
Now the question is where to find a filter capable of the 500 PSI max I should be at.
#62 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 19, 2016 - 07:11 PM
That filter is not the flow problem as I see it. It is what I use on my waste oil burner.  The low bypass pressure is not good for your application.  If you stay with it I would change it a lot more often to keep from bypassing dirt to the hydro unit.
These are some high quality filter for your application.
These filter have a 50 PSI bypass so there is less chance of blowing dirt into the high pressure side of the hydro and damaging it.
The Fleetgard HF 6446 has 7-9 GPM flow rate. This is top of the line Micro-glass filter.
John Deere uses it on there 2243 Greens mower
The Wix # crosses to 57102.
The Baldwin crosses to BT 8301
Edited by ducky, November 19, 2016 - 07:11 PM.
  • olcowhand and KennyP have said thanks
#63 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 19, 2016 - 07:49 PM
Kenny do you have a 716 manual?  I can not locate one in our manuals section.
#64 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 05:44 AM
I have both the Operators and Parts. I can upload them here in a bit.
The Operators Manual is already uploaded here.
Edited by KennyP, November 20, 2016 - 06:28 AM.
#65 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 06:33 AM
Here is the parts manual I have.
#66 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 20, 2016 - 10:48 AM
Thanks Kenny
The parts manual appears to only pertain to the gear transmission.
I got a look at the Hydro unit in the operators manual and it looks a lot like a 4012 hydro Allis I have. Could these be the same?
Just one more question.  Does the Hydro pump and motor look like the Eaton 11 in the service manual here.
Attached File  Eaton 1100-031 E-TRLD-TM001-E.pdf   1.84MB   24 downloads
#67 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 11:09 AM
Thanks Kenny
attachicon.gifEaton 1100-031 E-TRLD-TM001-E.pdf
This hydro is out of a Ford LGT, Don. It's in Alice now. So it is an Eaton 11/Peerless combo.
#68 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 20, 2016 - 11:34 AM
AHHHH. OK now I think we are on the same page.
This the same as A snapper.
Are you returning the oil from the valve to this port on the Eaton 11?
As this supplies oil to the hydro, when you do the test I asked be sure to run the tractor no longer than than you have to to prevent damage to the hydro.
I would also suggest that you rehook the lines back up and relube the hydro in between test also.
  • MH81, Alc and KennyP have said thanks
#69 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted November 20, 2016 - 12:03 PM
Ducky would this be the reason for such high return pressures ? Feeding the hydro
#70 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 20, 2016 - 12:13 PM
No the relief internal in the Hydro is set somewhere between 30-90 PSI.
Now if the relief is stuck or not bypassing at those pressures than Yes.
That is way I would like Kenny to disconnect their and see what the pressure is than with the valve in neutral.
#71 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 12:16 PM
Yes, that is where the return line for the charge pump/ valve hooks back in. I probably won't do anything with it til tomorrow though.
From the pic there, this is sitting 180° from your pic on a Ford/Jake.
#72 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 20, 2016 - 12:21 PM
Yes that is correct Kenny.
You should see a back pressure of 30-90 PSI with valve in neutral.
#73 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 12:34 PM
I'm wondering if the relief in the valve could be causing some of this? If it is set high, could it cause these type of pressures?
#74 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 20, 2016 - 12:41 PM
As far I know it is not adjustable.  Let's disconnect their and run into bucket and see what we have. Then we can Blame or eliminate the hydro as the problem.
#75 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted November 20, 2016 - 12:50 PM
This valve I'm using has an adjustable relief.
