Calling ALL Hydraulics Guru's!
189 replies to this topic
#31 olcowhand ONLINE
  • 43,162 Thanks
  • 32,011 posts
Posted June 22, 2016 - 01:08 PM
That hole will easily flow the max volume your charge pump can put out.
  • TheFarm2004, Alc and KennyP have said thanks
#32 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 22, 2016 - 02:36 PM
That was in the side of the pump for a return fitting. Something is causing every valve I put on there to leak at the rear of the spool.
#33 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 23, 2016 - 03:21 AM
Your rear fill cap/ vent is working correctly? My dad's leaked like a sieve out the front and rear. He took it apart and replaced the o rings now it's spotless, I need to do this to my 125 as well as it is starting to leak too. That fitting is used the balance the speed of a hydraulic cylinder, they use them on small backhoes for instance, on the main boom cylinders so it goes up and down smooth and linear.
#34 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 23, 2016 - 06:04 AM
Vent should be fine, it's high enough. I'm going to check a few more fittings, but it gets hot early around here. I don't like taking the fittings apart inside due to the mess.
Had to take yesterday off as my hand was hurting from changing the valves back out. Found a kit for the 2-spool. I'll get it in a week or so.
#35 toppop52 OFFLINE
toppop52
  • 5,596 Thanks
  • 4,941 posts
Posted June 23, 2016 - 08:53 AM
Hydraulics are like electricity to me, half science, half black magic.
  • KennyP and UncleWillie have said thanks
#36 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 23, 2016 - 08:55 AM
I'm learning!
Are the o-rings in these a Viton type?
#37 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 23, 2016 - 11:06 AM
The orings can be viton or Buna N or even Diesegren ( a whitish cream color) all will work, but viton is the best choice, diesegren are very $$$$ and made for extreme preasures and harsh environment.
#38 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 14, 2016 - 12:14 PM
Well, I finally have ordered the o-rings for the 2 spool valve. Also ordered a 2000 PSI liquid filled gauge to check pressure. Have to plumb in a tee to hook the gauge up.
  • olcowhand and SupplySergeant have said thanks
#39 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 17, 2016 - 01:46 PM
Got the gauge today! May see about hooking it in.
#40 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 17, 2016 - 03:20 PM
I got the gauge on it. Had an issue with a fuel line to fix to get her to run. Anyway here is what I found.
Here is what it shows at full throttle.
And here is what I get when I operate the lift handle.
At a fast idle, pressure drops to 200 and slowly climbs back to 300.
If there is a restriction, it has to be in the cylinder fittings and I will have to take it out of the tractor to get to them.
#41 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 17, 2016 - 03:54 PM
Here's the fuel line I had the issue with. Good stuff Motorcraft puts out.
I also pulled this plug (see arrow) to see if there was a restriction there. Looked all clear!
#42 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 18, 2016 - 10:45 AM
Bump!
#43 nbent ONLINE
nbent
    customizer
  • 679 Thanks
  • 540 posts
Posted November 18, 2016 - 11:58 AM
Have you tried putting the gauge on the return side of the valve to see if there is a high restriction
#44 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 18, 2016 - 12:01 PM
Not yet, but since it is an open center, didn't think that was needed. Would think it would read the same on both sides? Don't know! I'm no even sure what the readings above show.
#45 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted November 18, 2016 - 07:34 PM
Bump!
