Calling ALL Hydraulics Guru's!
189 replies to this topic
#181 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted December 27, 2016 - 04:44 PM
Got Alice out and checked to see how much she can lift. Put the 140 lb. Box Blade on, added 2 of my 40 lb. suitcase weights and she did fine. Added another 30 lb. cast weight and that's about it. So 250 lbs. is the max Alice can lift. Not bad as far as I am concerned.
  • olcowhand, dropped82, TomLGT195 and 1 other said thanks
#182 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted December 27, 2016 - 05:16 PM
Good to here Kenny.  Looks like you have it fixed.
#183 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted March 23, 2017 - 02:02 PM
I got Alice back out for more tests on lifting. I had an issue pop up after the last improvement on the 3-point lift. You can find that here. Starts in post #61.
Anyways, I hooked the box blade back up. Added the 160 lbs. of suitcase weights i made. That's 300 lbs. Lifted that fine. Went to the relief in the valve and tweaked it to max at 1000 lbs. Added another 70 lbs. And here is the pic.
Changed the one 30 lb. weight for the 50 lb.
Then added the 30 lb. back in, that adds up to 420 lbs. on my calculator.
And all this at less than 1/2 throttle! :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana: :worshippy1:
I am extremely HAPPY! There must have been something stuck in the relief! No more loud squeals at 1000 psi.
  • olcowhand, Alc, EricR and 3 others have said thanks
#184 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,168 Thanks
  • 1,227 posts
Posted March 23, 2017 - 02:52 PM
Good news!
You you have to love it when noises fix themselves!
Does this mean you're going to see the Northern lights again tonight? :beer:
#185 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted March 23, 2017 - 05:14 PM
Great job.
#186 EricR OFFLINE
EricR
  • 642 Thanks
  • 397 posts
Posted March 23, 2017 - 05:20 PM
I love when a plan comes together!!!
#187 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted March 23, 2017 - 05:30 PM
Good news!
A bit of celebration is in order, though I haven't opened that yet!
#188 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,721 Thanks
  • 971 posts
Posted March 25, 2017 - 07:58 PM
Glad to hear it Kenny!
#189 chris gauthier OFFLINE
chris gauthier
  • 15 Thanks
  • 25 posts
Posted December 19, 2017 - 11:36 AM
Kenny,check all your hyd lines at the fittings where they are crimped,sometimes they overcrimp,causing a restriction on the line,i would look on the return side of the valve,back to tank,same problem with 3 valves&you are sure of routing,check crimps,i`ve seen this several times
#190 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted December 19, 2017 - 03:33 PM
It's all working right now, Chris!
