Calling ALL Hydraulics Guru's!
189 replies to this topic
#151 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 02, 2016 - 08:40 AM
I have adjusted the drawing and have taken some of that downward angle out.
  • MH81, Alc and SupplySergeant have said thanks
#152 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 02, 2016 - 01:16 PM
Well, I hope no one sees any serious issue with that last drawing as I have the rockshaft built! Even added a grease zerk.
  • TomLGT195 and Mark 149 J. have said thanks
#153 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,012 Thanks
  • 1,093 posts
Posted December 02, 2016 - 01:31 PM
Fast work, Kenny! Looks good.
#154 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 02, 2016 - 04:26 PM
Since then, I have raised the mount point on the 3-point and made up the lift bar to it.
Now to build the courage to take the knife to Alice. Gonna have to take her out and turn around. That will give me more room. I dread removing wheel weights, they are heavy. Plus the wheel has to come off along with the fender and LH foot board! The tire and wheel weight 120 lbs.
  • Alc and SupplySergeant have said thanks
#155 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
I sourced the orings you need. This will do a complete 2 spool Valve including the spool seals Pt# 206.
Anybody want a set let me know.
$5.00 US free Shipping.
Can do Pay Pal.
We are changing the metric oring to an 012 American size.  The metric works but I feel the 012 is a better fit.
Could one of you Mods delete my post 103 to get rid of the other information.
When we get through this I will do an article with all this info in one place.
  • KennyP and TomLGT195 have said thanks
#156 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 02, 2016 - 04:29 PM
How about you get the new info posted and I link that post to the new one?
#157 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted December 02, 2016 - 04:35 PM
Kenny your drawnings will qork just fine yoyr well on your way. Especially if you could use that larger diameter cylinder from the deere?
#158 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 02, 2016 - 04:44 PM
I think that's out as I won't have space to mount it! Gonna be tough to get this cylinder in there!
  • GardnMastr said thank you
#159 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted December 02, 2016 - 05:03 PM
Will do Kenny
Will get it done this evening.
#160 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted December 02, 2016 - 05:07 PM
Count me in please.
Oh and anyone know what Wheel horse models use these valves?
Eric
Check your PMs
#161 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 03, 2016 - 01:17 PM
Turned Alice around so I would have more room to work. Started the surgery! Had to remove a shoe and some clothes.
When I took that pic, I noticed another issue with the brake. Gotta fix that while I'm in there!
Got the clothes off.
Got the brake band out. May be fun to reinstall!
And yet another issue with the parking brake holder. Have to fix that too!
I brought the brake and JB Weld in the house to warm up. I'll fix that later so it can dry good. I also have the oil filter hanger off and working on fixing that!
  • olcowhand, Alc and 29 Chev have said thanks
#162 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 03, 2016 - 04:24 PM
The brake band is setting up. I used JB Kwik on it. Got a few more things accomplished. The bar stock going from the front rockshaft to the 3-point was only 1/4" material. Was afraid it might try to bend. Had a piece of 3/8" square stock, so I stitched it to the side for more strength.
Got the filter mount done. Even squirted some black paint on it.
And the new parking brake holder is ready.
Would do more but it's getting quite chilly and damp out there and I don't want to start a fire this time of day.
  • olcowhand, Alc, TomLGT195 and 2 others have said thanks
#163 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 05, 2016 - 06:15 AM
Put the brake mechanism back in and found another pair of issues. Had to take more parts off to work on those. First, the rod to the pedal was rubbing the rockshaft.
And the parking brake shaft wasn't able to align to the hole.
Had to pull the 'box' off to make a notch for that.
Got some paint on things. Had to wait for that to dry.
My daughter came over, so the rest of the day was with her.
  • Alc, gopher, TomLGT195 and 1 other said thanks
#164 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 05, 2016 - 07:31 AM
Sitting here thinking, that brake rod to the pedal may be in the way of the new cylinder mount. Gonna have to look into that. Got COLD weather coming in a couple days (highs in the 30's).Hope I can have this back together tomorrow, but it will be pushing it.
#165 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 05, 2016 - 03:08 PM
Got a little done today! Spent most of the day trying to get the wood stove top put out heat. Got an upgrade coming for that, but that's next week! Mounted the 3-point and found another interference issue. Sorry for the blurry pic.
Took care of that and shortened the pin there. Here's a rear view. Without the cylinder attached I have more lift than before height wise.
Worked on some parts for the cylinder mount and gave up for the day. I'm freezing! Had a south breeze into the shop and it wasn't warm!
