Calling ALL Hydraulics Guru's!
189 replies to this topic
#1 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 12:55 PM
Got an issue with Alice! Every valve I have put on her leaks badly at the back end of the valve! I just put a 2 spool off an 1855 MF on there and now I can't lift the fork lift with an empty pallet. Lots of squealing going on. Anybody have a clue what the issue is?
  • 14,900 Thanks
  • 15,518 posts
Posted June 20, 2016 - 01:39 PM
Could be a blocked passage in the valve body. Some valves only allow oil to flow through it in one direction, could it be plumbed up backwards?
  • KennyP, boyscout862 and Auburn David have said thanks
#3 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 03:54 PM
I checked that before installation. Seems odd that every valve I put on here does the same thing (leak from the back side). And now no lift at all.
#4 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted June 20, 2016 - 04:21 PM
Low power and squealing relief valve. Drip out of caps bad o ring or scratched spool. As always when doing relief valves run gage to know pressure you have.
#5 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 04:25 PM
My biggest question it why 3 different valves? And it's not a drip! More like a flood! No $ for a gauge right now!
#6 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted June 20, 2016 - 04:41 PM
Blowing backside of three different  valves like Brian said you just about have to have plumbing running backwards. Or your hydro putting out way to much pressure.
#7 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 04:52 PM
It's not running backwards! Been checked many times! But I'll do it again!
#8 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted June 20, 2016 - 05:11 PM
Is there any chance you have a damaged hose or fitting?
Jim
#9 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 05:12 PM
Line from the charge pump is the inlet line, right? I thought I had the wrong filter on it. So I put the one that came with the filter adapter on. No change. Wondering if the return line from the filter is bad inside? I'm lost here!
#10 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 20, 2016 - 05:15 PM
Jim
Most all fittings are new. Guess I can OD the account and get a gauge and fittings to hook it up.
#11 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted June 20, 2016 - 05:43 PM
Did you take this valve apart?
#12 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted June 20, 2016 - 06:09 PM
Another way to get messed up pressure with two spool in tight quarters both spools hooked to same cylinder.Two hoses crisscrossed making dead head.
#13 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted June 20, 2016 - 06:44 PM
What is the Open flow and Closed flow systems mean?  Might have valve from the wrong type system? I would say a blockage also, blame the new valve for not being correct one or set-up. All leaking?  Too much pressure?  O-rings just got old and worn/dried out from when unit was outside setting those years?
#14 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted June 20, 2016 - 09:48 PM
Kenny
What's the model of you tractor?  Also is the return line from the valve open and routed to tank?
#15 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 21, 2016 - 03:18 AM
Kenny does this valve have power beyond?? If all your spools leak that bad, you have a low pressure return issue, something is not correct, and the flow is being blocked. Get a bucket and unhook the return hose and get the open ends in it. Start rig up at idle and see if you have good flow before and after filter, then check the fitting that goes into the hydro on the side to be sure all is well there and it has no restrictions .
The charge pumps on the Eaton 11 are not a hi pressure unit, the internal one is that drives them.
Edited by skyrydr2, June 21, 2016 - 04:11 AM.
  • Bruce Dorsi and KennyP have said thanks
