Cutting Wheat with the JD 95
12 replies to this topic
#1 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 18, 2016 - 11:32 PM
I got out there today with the old '59 John Deere 95 combine, it took some adjusting of the real but we got it cutting really nice. The old combine never sputtered or missed out, I drove it 6 miles to a friends field and cut around 3 acres then drove it back. Now I need to clean it out and put it away till next year.
Edited by BTS, June 18, 2016 - 11:34 PM.
  • olcowhand, Gtractor, Alc and 7 others have said thanks
#2 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 18, 2016 - 11:34 PM
That field was giving out 70 bushels per acre
  • boyscout862 and Sawdust have said thanks
#3 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted June 19, 2016 - 04:05 AM
Glad you got it going!
  • boyscout862 and BTS have said thanks
#4 Alc ONLINE
  • 7,259 Thanks
  • 7,598 posts
Posted June 19, 2016 - 05:03 AM
Nice ! Are you happy with the way it seperates the wheat/stalks ?
  • BTS said thank you
#5 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 19, 2016 - 08:06 AM
It seemed to separate the wheat pretty good, we had some wheat heads in the grain tank but Dave (the farmer friend I was cutting with) said that their new Case IH combine does the same thing because the wheat sent up suckers and those heads were still green. The combine was leaving quite a bit of grain  behind when we realized there was a big rust hole on the auger tube on the bottom of the combine, I got it all taped up and then it wasn't hardly leaving anything behind.
For being 57 years old, the old combine did great
  • olcowhand, Alc and Sawdust have said thanks
#6 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 19, 2016 - 08:07 AM
Here is a better video
  • Gtractor, Alc and Sawdust have said thanks
#7 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted June 19, 2016 - 08:08 AM
The old girl sounds & looks good!
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,936 Thanks
  • 6,386 posts
Posted June 19, 2016 - 08:49 AM
Looks like it works pretty darn good.
#9 glgrumpy ONLINE
  • 8,816 Thanks
  • 8,014 posts
Posted June 19, 2016 - 10:20 AM
Putting away?  So, over the winter the Mice come in and find the "stock" of left-overs and make nests, eat the wiring and other things. In spring will be gone and leave junk behind!  AND, I'm not familiar with Wheat Duct Tape, that diff stuff that holds up better than standard?  Ha! :poke: :smilewink:
#10 chieffan ONLINE
  • 11,408 Thanks
  • 7,137 posts
Posted June 19, 2016 - 12:36 PM
Cut around 3 acres then drove it back?  Wasn't enough to bother getting it running for.  That is about what I start with when I mow my lawn.  3 trips around and ready for the straight line mowing with room for turning on the ends.
#11 Sawdust OFFLINE
Sawdust
  • 6,155 Thanks
  • 3,549 posts
Posted June 19, 2016 - 01:19 PM
Ejoyed watching it still working after all these years. Sounds good too.
#12 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 20, 2016 - 07:42 AM
I thought about not putting it away and I will just run it and cut endless wheat all summer and winter but I figured that probably wouldn't work either.
I didn't say duct tape, it was clear packing tape, it stuck down and held great, I will get out the torch and braze in patches this winter.
Edited by BTS, June 20, 2016 - 07:45 AM.
#13 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 20, 2016 - 11:07 AM
The 3 acres that I cut was just testing out the combine, next year I am planing on cutting around 10 acres of my friends wheat to clean out the combine again and then I will cut my 5 acres of organic old fashion wheat (turkey red). I like to cut my friends wheat since his isn't food grade and mine is, it's a good way to get the combine shined up and get the gunk cleaned out.
3 Acres doesn't sound like much till you are cutting it by hand and thrashing it, a $500 combine sure seems worth it if you look at it that way.
  • toomanytoys84 said thank you
