Sprayer Project
24 replies to this topic
#16 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted June 21, 2016 - 07:49 PM
Can you tell me the # and make of the tips you used?
  • michael.kitko said thank you
#17 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted June 22, 2016 - 05:32 PM
I'd be curious on that too. I am currently using two #3 flood tips from tractor supply, and a center #2 down spray tip. The floods I have turned sideways. I am also running mine at 18" spread with a 20" tip to ground clearance.
Mike "Squirrelly" Kitko
Edited by michael.kitko, June 22, 2016 - 05:38 PM.
#18 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted June 26, 2016 - 11:20 AM
Sorry it took me so long to get back to this, been working some long hours this past week.
These are the nozzles I'm using...
I've got em set at a 40" spacing and about 20" off the ground although I believe 18"-24" is allowable on these.
Edit: I forgot to say that I found these ones at farm and fleet, if that helps anyone.
Edited by Walkinman1, June 26, 2016 - 01:07 PM.
  • ducky, michael.kitko, stiemmy and 1 other said thanks
#19 MNGB ONLINE
MNGB
  • 1,969 Thanks
  • 1,334 posts
Posted July 13, 2016 - 07:51 PM
Hi Walkinman1, I'm finally back to working some and have made some good progress on the 3 PT sprayer conversion. I have a question what spray / boom pressure are you using? Have you had the sprayer out and used it if so how is it working?
Thanks
#20 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted March 04, 2017 - 10:35 AM
I know this was a long time ago but I just now saw your reply, did you ever get yours finished up and working?
#21 MNGB ONLINE
MNGB
  • 1,969 Thanks
  • 1,334 posts
Posted March 04, 2017 - 12:38 PM
Hi, yes I used it last fall and it worked very good I like it sprayed about 10 acres with it, will see this spring what kind of a job I did.
Here's a thread on the 3 pt sprayer fabrication
http://gardentractor...yer#entry713832
Edited by MNGB, March 04, 2017 - 12:45 PM.
#22 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted March 09, 2017 - 06:07 PM
Looks good! Glad to see it worked well for you, I still need to get around to getting mine painted...I have way too many projects...
  • MNGB said thank you
#23 Cvans ONLINE
  • 6,453 Thanks
  • 6,051 posts
Posted March 10, 2017 - 11:09 AM
You really have a nice outfit there. Not just the sprayer but the tractor and loader also.  :thumbs:
#24 toppop52 ONLINE
toppop52
  • 5,010 Thanks
  • 4,627 posts
Posted March 10, 2017 - 11:26 AM
You did a great job with that! I have a 15 gallon tow behind that I've been wanting to convert to hitch mount. I have a 3' boom with 2 nozzles that gives about 6' of coverage. I don't need a lot more for my 16' wide clam shell driveway, but hitch mount would be handy.
  • Walkinman1 and MNGB have said thanks
#25 Kster526 ONLINE
Kster526
  • 820 Thanks
  • 544 posts
Posted March 10, 2017 - 01:52 PM
Nice job on the sprayer .
  • Walkinman1 said thank you
