Ready to repower - unsure of choice - please look -
61 replies to this topic
#31 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted September 09, 2016 - 12:47 PM
Needing the following parts:
(1) 1719852 ET-8484 Gasket (Transmission Cover)
(1) 1719857 ET-8465 Gasket (Button Assembly)
(1) 1720309 ER-8277 "O" Ring (Filter Stud)
(1) 1719862 ET-94426 Seal Washer (Mounting Bolt)
(1) 1720310 ER-8284 «O» Ring (Dipstick)
(1) 1719866 ET-8369 «O» Ring (Connecting Tube)
(2) 1719869 ET-94897 Sealing Washer - 11, I.D. (Parking Pawl)
(1) 1719871 ET-62087 Parking Pawl (park does not work anymore?)
(2) 1719877 ET-94276 Oil Seal (Axles)
(1) brake disk (mine wore out, 3/8" slop)
(1) seal for input shaft on eaton 12 (where drive shaft connects to)
  • accidentalchild said thank you
#32 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted September 09, 2016 - 03:31 PM
Sent you a PM.
#33 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted September 16, 2016 - 09:23 AM
Ok, waiting for parts to arrive before tearing into the Eaton 12 transaxle. Finally repaired the rot on the foot section of the rear fender section, weld - grind, and repeat. Rear fender / hood all in primer awaiting paint...Need to get some new pictures up here. Will work on that this weekend.
  • Austen, nglauer and accidentalchild have said thanks
#34 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted September 20, 2016 - 12:16 PM
So, could not for the life of me figure out how to remove the hydrostatic package from the transaxle!! Then I pulled the manual, LOL one bolt in the rear!!! At least all the O-rings are replaced, so now onto the axle seals.
  • LPBolens, nglauer, ClassicBolens and 1 other said thanks
#35 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted September 21, 2016 - 06:31 AM
Granted, this is taking sometime to do, as I have 3 herniated disks and a broken rib.
  • nglauer and accidentalchild have said thanks
#36 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted September 22, 2016 - 07:17 AM
Rear axle seals in!!! Yea!! Just have to install new brake pads, reassemble and paint! Then install the engine.
  • Austen and accidentalchild have said thanks
#37 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted October 11, 2016 - 09:42 AM
Need pictures!!! Someone tell 3rd shift after their done cleaning up, please take pictures!!!! Hood came out spanking nice! working on rear fender tub currently. Mounted new Vredestein v61 tires on front, WOW crazy nice. What wasn't so nice, was that whomever owned the previous tires, put some kind of red slime in them, that was not fun.
#38 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted October 11, 2016 - 01:42 PM
Sounds great!
So where's the pics? :)
#39 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted October 12, 2016 - 06:52 AM
Looking for a brake pedal rubber pad? Goes over the bare metal pedal....does not need to be model specific, as long as it fits.
Thanks
#40 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted October 12, 2016 - 10:12 AM
Thanks
I'd contact our Bolens part suppliers. I got mine from Brian. I remember he said that he comes across them every once in a while but is not something that he always has in stock.
#41 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted October 13, 2016 - 06:47 AM
Ok, some pics..........
Edited by KennyP, October 13, 2016 - 07:45 AM.
Adjust Gravity
  • stiemmy said thank you
#42 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted October 13, 2016 - 09:19 AM
Looking good
  • bprzyw said thank you
#43 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted October 13, 2016 - 09:37 AM
attachicon.gifpost-53276-0-36657500-1476359197.jpg    attachicon.gifpost-53276-0-12977100-1476359205.jpg
attachicon.gifpost-53276-0-96560600-1476359212.jpg    attachicon.gifpost-53276-0-83045300-1476359218.jpg
attachicon.gifpost-53276-0-56601600-1476359226.jpg    attachicon.gifpost-53276-0-12720600-1476359233.jpg
That looks great!! Gets me wound up now wanting to redo 1 of mine. Thanks for the pics, and I am following this topic 4 sure;)
Thank you Kenny for rotating the pics. (Thumbs up)
  • KennyP and bprzyw have said thanks
#44 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted October 13, 2016 - 09:43 AM
stiemmy, thanks for rotating those. I was in a rush.
#45 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted October 13, 2016 - 10:44 AM
Sweet!
