J.D. 110 STARTER GENERATOR, DID I HURT IT ? HELP ! ! ! !
16 replies to this topic
#16 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted June 23, 2016 - 05:42 PM
My helper.
  • KennyP, Trav1s and hdg4400 have said thanks
#17 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted June 23, 2016 - 09:23 PM
Thank all of You again.
All suggestions was applied, points in the regulator were filed then wiped clean, a grounding strap from the regulator to the battery was added. The gen. indicator light repaired and it now is charging at 12.60 volts.
The gen light comes on with the key then sort of slowly fades out in a couple or three seconds.
I also installed a new starter solenoid, that did wonders for what I thought was going to be a weak starting system. Did not have to pull the engine over off of compression to get it to crank over, like what I was having to do previously.
Thank You again.
This little beast is coming along nicely.
