RT5000 CD unit replacement
9 replies to this topic
#1 B frank OFFLINE
B frank
  • 1 Thanks
  • 2 posts
Posted June 16, 2016 - 08:58 AM
The CD unit failed and is obsolete.  Has anyone found a 2nd source for the ignition control module part no. 30580-ZE3-790 or a schematic to make a work around unit.
#2 boyscout862 ONLINE
  • 12,830 Thanks
  • 9,158 posts
Posted June 16, 2016 - 09:58 AM
Welcome to GTT. Check with our sponsors for the part. Good Luck, Rick
#3 jms180 OFFLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted June 16, 2016 - 02:57 PM
Boats.net  kind of pricy at $105.00 Looks like same as cycle CDI box. Capacitive discharge ignition
Edited by jms180, June 16, 2016 - 03:04 PM.
#4 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted June 16, 2016 - 03:37 PM
That looks like one of those cheap Chinese scooter CDI boxes.Wonder if you could make 1 of those work? There like $8 shipped from hong kong.
http://www.ebay.com/...0NUloaT&vxp=mtr
Does your tractor have the single cylinder Honda GX340 in it? If so you could wire one of those cheap CDI boxes up and it will work.
#5 jms180 OFFLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted June 16, 2016 - 04:12 PM
maybe worth try
#6 B frank OFFLINE
B frank
  • 1 Thanks
  • 2 posts
Posted September 10, 2016 - 01:40 PM
Thanks for the Help and suggestions. All of the suppliers contacted reported back that the unit was obsolete and not available. I found a Chinese motorscooter CD unit for a GY6 50cc 125cc 150cc 4 stroke.  Amazon Bangood Product NO 975502 SKU 220424.  It has an identical connector, plugged in and started.  It is slightly larger and the rubber cushion had to be removed to fit.  Otherwise OK . It came with a coil and spark plug which were not used.  cost about $12.00
Combination relay for the starter circuit failed and was replaced with a starter solenoid from Drive Works (Advance Auto) NO DW-755 and push button starter switch from Autocraft NO 85935 also Advance.  The solenoid mounts without drilling or modification on the two studs that support the air cleaner above the starter motor.
Belt from PTO to mower drive was replaced with Kubota LB 89.  Number on the belt is D&D MegaPower Drive BK87 5L900 21/32 2011-11.  It takes the flex and bend from the PTO around the idlers/direction change without a problem.
#7 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted September 11, 2016 - 05:58 AM
Glad you got it running .Thanks for the follow up .
#8 tom bauer OFFLINE
tom bauer
  • 2 posts
Posted May 26, 2017 - 09:32 PM
yes this will 'work' but is very bad for engine as it does not have the advance curve designed for that engine. they can be repaired.
#9 scottnrobin OFFLINE
scottnrobin
  • 1 posts
Posted May 30, 2017 - 10:28 AM
I own an RT5000 with 46" belly mower, 42" rear mount brush hog, Tiller, dozer blade, plow and spring tooth cultivator.  People complain that some of the engine parts are no longer available.  I was wondering if you could just drop a new honda GX-340 engine on this chassis if necessary without major modifications?
#10 tom bauer OFFLINE
tom bauer
  • 2 posts
Posted July 17, 2017 - 02:17 PM
entirely different crankshaft, just rebuild yours. new and repaired CDI available at freedom cycle. (i make them for them)
