How's about a canopy for a GT?
garden tractor canopy ac 718h mod. canopy
127 replies to this topic
#1 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 01:51 PM
I haven't posted this anywhere as I wanted to see if it would work. This is an add-on for Alice, my 718H Modified tractor. I got a yard swing with a canopy, but the cover was long gone. I got to looking at that frame and thought why not a GT canopy. After a little work, I had a GT sized frame. Next was building something to hold it up there. It gets quite hot down here during the summer and I thought a little shade would be nice. No skyhooks available to keep a cloud over me & Alice. So I got to work.
I knew I would be taking Alice apart soon for some other needed items. So I made a frame from some 1"X1" square tube laying about. I may have gotten it a bit tall, but that can be changed. I wanted it high enough so folks didn't have to bend over to much to get on Alice.
Anyways, here is where I am at the moment. I have a piece of white rubberized tarp I plan to make the cover out of.
Alice is apart right now for the fixes. As soon a She is back together, I have the frame mounted and we can all have a look-see.
  • olcowhand, Gtractor, Alc and 17 others have said thanks
#2 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted June 15, 2016 - 02:53 PM
I saw a post from last night (or early this morning) about you making repairs to your GT and saw the start of the canopy in one of the photos.
Great idea!
#3 jms180 OFFLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted June 15, 2016 - 03:07 PM
That is a great idea Kenny looking forward to some more pictures
#4 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 03:14 PM
I'm working on it, guys! Gotta let paint cure some so I can put her back together. My biggest issue will be if the frame isn't solid enough to hold it fairly steady. If that works, then I'll cut a piece of the tarp and pop rivet it on. Too cheap to buy snaps! Stay tuned!
  • Sawdust and propane1 have said thanks
#5 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 15, 2016 - 03:29 PM
Only trouble I can see is the exhaust, can't really see how close it is but pointing straight up it is likely to direct the fumes at you while running hi rpm. Otherwise I like it!!!!
#6 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 03:36 PM
Exhaust is several feet forward of the canopy! I'll get pics when it can put it all together. But that should not be an issue!
#7 John Arsenault OFFLINE
John Arsenault
  • 2,600 Thanks
  • 1,217 posts
Posted June 15, 2016 - 03:41 PM
Dang it!! by the title I thought you were giving away a canopy....lol
Honestly...Thats me all the way , I am not to fond of a cab but like that a lot. I think I have the same canopy swing top to. Hmmmm A little sheet metal top welded on and it can be good for snow to Hmmmmmm.
#8 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 03:55 PM
Gotcha thinking now! Not enough snow here, but plenty of sun!
#9 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 15, 2016 - 04:15 PM
   I have a long 445 diesel tractor and the exhaust is the same way, straight up and about 3' in front of the drivers seat.  I put a canopy on there to bush hog fields so I didn't get burned to death by the sun,  the fumes were so bad I had to re-route the exhaust down and under to get away from the problem.   Hope this works out for you as I want to do something for allis when I run the sickle mower.
        Pete
#10 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 04:22 PM
        Pete
I'll be finding out!
#11 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 15, 2016 - 05:44 PM
Just a thought but that is a pretty big canopy and have you figured on bracing it for wind? maybe even just a cable to the hood or something might protect you from a strong gust.
#12 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted June 15, 2016 - 05:51 PM
That's a thought! Won't know anything until I can bolt a few things together!
  • Eric said thank you
#13 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted June 15, 2016 - 05:53 PM
Not a fan! Looks too light and flimsy, I'ld pass!  The Other Side! Hee!  Just do a heavier roll-over bar at back and put a top on that section, just like the real ones.
Edited by glgrumpy, June 15, 2016 - 05:54 PM.
#14 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,416 posts
Posted June 15, 2016 - 07:09 PM
:watch_over_fence:
#15 chieffan OFFLINE
  • 10,179 Thanks
  • 6,651 posts
Posted June 15, 2016 - 07:44 PM
Remember the higher you make it the more sun it will let in, especially on the sides.  Definitely will need bracing on the front.  I had thought about putting a regular tractor umbrella on my one mowing tractor.  Too many trees to mow around and under for that to work.  Guess I will get be a big wide brim Sombrero.
  • KennyP and Sawdust have said thanks
