The Dissection of Alice!
ac 716 ac 718h modified allis chalmers
27 replies to this topic
#16 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted June 15, 2016 - 01:55 PM
OH, I could use a canopy here!
#17 bbuckler OFFLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted June 15, 2016 - 01:57 PM
Yep it would be nice to have while riding around at the tractor show,
  • KennyP and Sawdust have said thanks
#18 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 15, 2016 - 02:59 PM
Check out the thread here.
I could not put that Red valve on Alice. So with a little effort, it is now Orange!
I will wait until tomorrow morning to start putting her all back together. Gotta let the paint cure some! I miss having her to ride around on!
  • olcowhand, gopher, Sawdust and 1 other said thanks
#19 UncleWillie OFFLINE
  • 15,523 Thanks
  • 8,704 posts
Posted June 15, 2016 - 05:53 PM
Build it, break it, build it better.
I love the attack turtles sign.
#20 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 16, 2016 - 08:28 AM
Got out early before the heat arrives (think it's already here). Got the 3-point bolted back to the box.
Put the valve back together.
And the box is installed.
The 3 gold headed bolts are what holds the box to the frame. 3 per side. The one furthest left is the one I added. Thought going through the 3-point mount might hold things better.
Now I'm ready to swap the hoses to the new valve and mount it. Then everything else goes back on. Alice may be running before lunch!
  • olcowhand and Alc have said thanks
#21 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 16, 2016 - 09:54 AM
I decided to put the fender and seat up there to see how close the valve was going to be. Good thing! The valve is too high and too far out. Need to move it 1/2" each way. That will put the lines real close to the fender, but I already figured out how I can move them outboard 1/2" real easily. Nothing major, just a slight delay.
#22 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 16, 2016 - 05:24 PM
Got the valve hooked up and working! Bushings for the fenders are painted and waiting for those to dry. I can finish putting her together tomorrow! I'm ready for that!
  • olcowhand, Alc, CRFarnsworth and 2 others have said thanks
#23 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,030 Thanks
  • 2,651 posts
Posted June 16, 2016 - 06:30 PM
Looks good - just in time for a weekend tour of the neighbourhood with the canopy on.  A suggestion for the canopy would be to make the cover in 3 or 4 pieces and leave them so the overlap could breathe at the join.  May use a bit more material but might prevent it from acting like a sail - just a thought.
#24 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 17, 2016 - 05:06 AM
That would be beyond my capabilities. One piece will be a challenge for me to get attached.
Shouldn't take too long to get everything back in place this morning. My hand is doing great, not hurting much and swelling is slowly going down. Hardest thing to put back on will be the tires @ 160 lbs each. But I have a plan for those.
  • olcowhand said thank you
#25 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted June 17, 2016 - 05:34 AM
Your doing a very nice job fitting the valve along with making the controls  and hitch  :worshippy1:
#26 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 17, 2016 - 05:52 AM
I work with metal much better than fabric!
#27 KennyP ONLINE
  • 37,432 Thanks
  • 45,468 posts
Posted June 17, 2016 - 10:37 AM
She's all back together! WooHoo! Fender shims worked out great. Had Steve help with the back tires. I'll put the fork lift on later and see in the lifting is any better.
Pics of the canopy frame mounted are here.
  • olcowhand, TomLGT195 and Mark 149 J. have said thanks
#28 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted July 01, 2016 - 10:30 PM
I recognize the sheet metal on the dash tower but what is the rear end?
Also tagged with one or more of these keywords: ac 716, ac 718h modified, allis chalmers
