Wheel Horse c-100 vs Craftsman gt3000
27 replies to this topic
#16 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 14, 2016 - 11:00 PM
Does anyone know where I can get a battery for this c-100 or what kind it takes. Thanks.
#17 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,768 posts
Posted June 15, 2016 - 06:54 AM
Do you have Tractor Supply Co  or Farm & Fleet in your area? They sell a 350 amp battery for garden tractors.
  • KennyP and Devron30 have said thanks
#18 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 15, 2016 - 07:57 AM
Sorry the battery with the tractor is new so will not need a battery. I was mistaken.
On a side not does anyone know the type of transmission oil the c100 takes? Thanks
Edited by Devron30, June 15, 2016 - 07:58 AM.
#19 KennyP ONLINE
  • 38,172 Thanks
  • 45,835 posts
Posted June 15, 2016 - 08:16 AM
The Atwoods here sells 420 CCA L&G battery's. Those are about $50.
  • Devron30 said thank you
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,768 posts
Posted June 15, 2016 - 08:22 AM
The 8 speed trans uses a good 110 weight rear end lube.
#21 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 15, 2016 - 08:28 AM
Thanks guys! Appreciate all the help you giys given me
#22 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,768 posts
Posted June 15, 2016 - 11:02 AM
I'm glad your changing out the trans lube. Over time the shifter boot tends to deteriorate and then water gets in the lube.
#23 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 15, 2016 - 12:45 PM
Perfect thanks for everything
Edited by Devron30, June 15, 2016 - 12:48 PM.
#24 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 15, 2016 - 01:54 PM
Another question. I have size 23x8.50-12 ag tires on this c100 and I'm looking to add wheel weights. Anyone know where and what I can buy these and does it have to be WH brand? Thanks
#25 John Arsenault ONLINE
John Arsenault
  • 2,524 Thanks
  • 1,197 posts
Posted June 15, 2016 - 05:12 PM
You can check craigslist 90% of whats out there fits the 12" wheels does not matter what name brand. If you get the ones with the hole in the center you can still take your tires off with out removing the weights.
#26 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 19, 2016 - 09:50 AM
Hey guys, I'm trying to remove the rear hitch so I can install my sleeve hitch. Any idea on how you get the big pin out that holds rear hitch on?
Quote Edit
#27 MolonLabe ONLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted June 19, 2016 - 10:04 AM
Quote Edit
First - Clean the rust off the exposed parts of the pin with emery cloth or sand paper and file down any burrs or mushroomed ends.
Second - Apply penetrating oil liberally and be patient, do this over the course of several days.
Third - Try to hammer the pin out but don't get carried away, I have seen several that have broken the transmission lugs doing this.
Fourth - Heat, lots of heat and a pair of vise grips to rotate the pin. If you can get it to rotate you will eventually get it out.
Fifth - Good luck, they can be a real bear to remove.
If I have to pull a pin I always install a grease zerk in the housing, just a little extra insurance.
Edited by MolonLabe, June 19, 2016 - 03:08 PM.
#28 Devron30 OFFLINE
Devron30
  • 5 Thanks
  • 13 posts
Posted June 20, 2016 - 01:42 PM
Any idea where I can get a new bolt for that? Thanks
