Allis Chalmers 310 wiring diagram
8 replies to this topic
#1 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 13, 2011 - 09:46 PM
Hi All,
Would anyone have a wiring diagram for a 1971 AC 310 garden tractor, The owners manual for our 410 has a different coil and PTO than the 310. I would like too get this rewired soon.
Thank you,
Mike
#2 MH81 OFFLINE
Posted May 13, 2011 - 11:04 PM
Howdy from NW PA!
If that is a simplicity built unit, you may be in luck. Let me do a little sleuthing & get back to you.
:welcome: to GTTalk!
#3 caseguy OFFLINE
  • 1,628 Thanks
Posted May 13, 2011 - 11:05 PM
:wave: case442 Welcome to GTTalk! Great to have you with us! I'm afraid that I don't have the information that you're looking for though. Hopefully someone will come along soon who can help. I know exactly where Sewickly is! My oldest Son was born at Sewickly Hospital! I live near New Castle these days though. We hope that you enjoy the forum and come back often. Looking forward to hearing more about your 310 and maybe seeing some pics!
#4 MH81 OFFLINE
Posted May 13, 2011 - 11:18 PM
It doesn't appear that there is an identical Simplicity version of the 310, but the 3310 seems close.
Here is the parts manual for both the hydro and vari versions of the 3310. May not be exact, but on pg49 of the PDF, there is a wiring diagram.
Hope this helps, if it's not right or close enough, please let us know.
Parts 3310:
http://bsintek.basco...rE3CG.5kbp796Dq
Owners 3310:
#5 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 14, 2011 - 07:11 AM
Hi All,
Thank you for the replies, my 310 wiring does not seem to be the same as the simplicity 3310. I guess my question is the 310 has a single wire magneto and not a coil as our 410 model does, however I have a wire remaining that is coming out of the points cover and I don't know were this goes.
By the way I also have a 1959 700 simpicity with a push blade, wheel weights and chains balast counter weight original dumping yard cart with brakes, and a 42" sickle mower. As well as a1948 model D walk behind with the cultivators and a 30" sickle mower.
#6 MH81 OFFLINE
Posted May 14, 2011 - 08:09 AM
Is that a single cyl Briggs? If so the 2 wires external to the cover are kill wires. One goes to the switch, and one to the mag. If these are disconnected it'll run, but not shut down. Do you have a picture of the area you're talking about? If so, post it and we will try to help.
Here's a link to another post regarding a similar situation. http://gardentractor...age2/#post61695
And a continuation of the problem. http://gardentractor...ss-2012-a-6237/
Edited by MH81, May 14, 2011 - 08:16 AM.
#7 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted August 10, 2011 - 11:54 AM
As far as I know, Allis-Chalmers built the 300 & 400 Series, not Simplicity.
#8 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted August 10, 2011 - 11:56 AM
The 300 & 400 series tractors should have Kohlers.
#9 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted August 10, 2011 - 01:23 PM
These are out of my 300 Series Service Manual
Just choose the type of ignition you have.
Breaker Point Ignition System
http://gardentractor...ache=1313000219
Magneto Ignition System
http://gardentractor...ache=1313000528
Hopefully, one of these will help.
