Z820A pto problems
2 replies to this topic
#1 Ronnie OFFLINE
Ronnie
  • 2 posts
Posted June 13, 2016 - 07:45 PM
Have a Z820A zero turn that PTO disengages soon as you release button. Battery was bad so replaced it. Still want stay engaged. Have checked wiring harness but no luck there. Mower only has 250 hrs. Clutch has already been replaced about 100 hrs prior. Where should I look now?
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 13, 2016 - 08:13 PM
I would check all safety switches for continuity when switched, then if its a newer mower check any fuses and all wire connections for corrosion and or damage.
#3 chieffan ONLINE
  • 10,898 Thanks
  • 6,922 posts
Posted June 14, 2016 - 07:06 AM
That new a mower still under warranty?  Like Eric said check every safety switch good and make sure you catch them all.  Seat and brake are the two most common problem areas.  Your may have others.
