Kohler hydraulic pump mount
8 replies to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 13, 2016 - 07:34 PM
This is how it's done.
  • toomanytoys84 and Auburn David have said thanks
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 13, 2016 - 08:15 PM
How what is done? If you mean hydraulics yes that is one way, a little backstory or information would go a long way towards me understanding your exitement.
  • Username said thank you
#3 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 13, 2016 - 09:48 PM
I never said that I was excited (I am though).It's gear drive.Do you have any ideas how it was done?
#4 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 13, 2016 - 10:24 PM
I have not seen a mount like that one on a single but have seen many gear driven hyd pump setups. The pump in the pic is identical to a pump I have here that came off of a forklift. That is a clean install though and looks as if it belongs if only the proper fittings and lines would have been used. As a rule even on input sides of pumps friction fittings with clamps are not advisable due to the nature of hydraulic systems. While working in the Navy I have seen even lower presure systems do significant damage to human skin, a pinhole in a 3000 PSI system will take your fingers off like a hot knife through butter while doing wipe downs! Fluid under pressure is nothing to be played with lightly.
  • Username, KC9KAS and propane1 have said thanks
#5 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted June 14, 2016 - 06:42 AM
Cam gear bumped out there?  Not sure how you open the case to use it?? That a kohler or some other like a Wisconsin say?  Using the Magneto drive part w/out the mag on it??
#6 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 14, 2016 - 08:02 AM
I thought it was interesting  how he drives the pump.The mount is home made and he cut the cam gear off another crank and mounted it to the pump.
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 14, 2016 - 09:28 AM
Thats looks great..and my 6018 has clamps on the low side(feed side) from the factory..as does my Toro 328D
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,865 Thanks
  • 5,952 posts
Posted June 14, 2016 - 08:48 PM
Looks good but seems like a lot of work when a simple mount and belt would do the same.
Sent from my XT1254 using Tapatalk
#9 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 14, 2016 - 10:48 PM
Low pressure systems frequently have clamps on them on the inputs, ussually as a cost cutting measure. I am not saying it is lethal, just a better idea to run proper fittings, I was always taught to use the same fittings on low pressure systems as on higher pressure systems just to be safe. I was always working hydraulics on aviation equipment where failure even in small ways can cause big problems. In my opinion saving a buck is not worth the hassle of chasing a leak or failure.
