starting a 7hp kohler
cub john deere
4 replies to this topic
#1 case1man OFFLINE
case1man
  • 160 Thanks
  • 118 posts
Posted June 13, 2016 - 07:24 PM
trying to start a 7hp kohler motor out of a cub cadet original no wiring harness and has a starter generator. Tried to pull start no go . Need to get power to points any ideas
#2 Bolens 1000 ONLINE
  • 13,714 Thanks
  • 17,627 posts
Posted June 13, 2016 - 07:31 PM
Does this have a 12vt coil or is it magneto ignition?
Coil ignition requires a 12vt power source (battery) to make the spark
  • boyscout862 and case1man have said thanks
#3 case1man OFFLINE
case1man
  • 160 Thanks
  • 118 posts
Posted June 13, 2016 - 07:33 PM
12v coil whats the best way to get power to coil
Edited by case1man, June 13, 2016 - 07:34 PM.
#4 Bolens 1000 ONLINE
  • 13,714 Thanks
  • 17,627 posts
Posted June 13, 2016 - 07:43 PM
To test it out take a small lead to the coil and ground on the engine
Dont leave it on too long or your burn the points , also may want to connect the final lead with needle nose pliers to the coil as it will spark a little as your putting power directly to the coil
  • CRFarnsworth and case1man have said thanks
#5 case1man OFFLINE
case1man
  • 160 Thanks
  • 118 posts
Posted June 14, 2016 - 07:50 PM
Thanks have it running no smoke , no noises good little engine
