Allis Chalmers b112 Sickle Bar Question
30 replies to this topic
#1 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 12, 2016 - 05:21 PM
Would anybody happen to have a pic of a sickle bar mower on a b112?
Mostly interested in how they lift and what the lift looks like. Thank you in advance
#2 boyscout862 ONLINE
  • 12,845 Thanks
  • 9,169 posts
Posted June 12, 2016 - 06:14 PM
I don't have a pic but, there is probably a manual for it in our Manuals Section. Look under AC and Simplicity. Good Luck, Rick
Try this one: http://gardentractor...-owners-manual/  and this one  http://gardentractor...kle-bar-mowers/
Edited by boyscout862, June 12, 2016 - 06:20 PM.
#3 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 12, 2016 - 07:19 PM
Ok thanks. I'll check it out. Just wanting to see if the the one I'm about to get is complete
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 12, 2016 - 09:25 PM
DSCN3717.JPG IMG_0163.JPG IMG_0168.JPG IMG_0176.JPG IMG_1463.JPG IMG_1469.JPG IMG_1471.JPG
  • bb1980 and JC 616 have said thanks
#5 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 04:12 AM
attachicon.gifDSCN3717.JPGattachicon.gifIMG_0163.JPGattachicon.gifIMG_0168.JPGattachicon.gifIMG_0176.JPGattachicon.gifIMG_1463.JPGattachicon.gifIMG_1469.JPGattachicon.gifIMG_1471.JPG
Thanks New Canadian. So is that a cable used to lift the sickle arm itself? And you can use it set at different angles for hills and stuff?
#6 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 04:57 AM
Here's what I'm looking at picking up. More concerned with the sickle bar and what the lift part is called and if you can buy just that part.001.JPG 002.JPG 004.JPG 005.JPG 003.JPG
#7 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 04:58 AM
And the deck has wooden rollers. Pretty sure that wasn't factory. If anything else looks out of place please point it out. I know the seat is wrong and something looks odd about the hitch too
#8 Talntedmrgreen ONLINE
  • 3,273 Thanks
  • 2,306 posts
Posted June 13, 2016 - 07:56 AM
Two of the tractors pictured have the rear chain support attached incorrectly...you do not want it attached to your lift rockshaft arm, or the rear of your mower will lift and lower, when it should remain level to avoid belt wear.
Note the chain to the bracket bolted to the frame:
#9 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 11:04 AM
Its mounted wrong in the one I posted? Also are these manual or hydraulic lift?
#10 ACmowerguy OFFLINE
ACmowerguy
  • 405 Thanks
  • 364 posts
Posted June 13, 2016 - 07:30 PM
These tractors could be equipped with an optional hydraulic lift kit but the tractor you're looking at specifically, does not have hydraulic lift. Its missing the rear chain bracket as Josh points out but that's an easy part to make. The headlights aren't original.  The rear hitch looks like the factory front/rear ball hitch accessory with the side tabs cut off.
http://www.simpletra.../ball_hitch.htm
  • JC 616 said thank you
#11 ACmowerguy OFFLINE
ACmowerguy
  • 405 Thanks
  • 364 posts
Posted June 13, 2016 - 07:37 PM
In addition to my previous comments, I also noticed the knifebar may be broken or out of place as you can see the knifehead and first few sickles in the circled part of the picture. Normally these would not be visible.
#12 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 07:49 PM
Yeah I see that...like the bottom should be twisted back to cover those? I see on the tractor on the side it has a pulley and cable to the sickle. Is that what lifts it then? How do you tell if its hydraulic lift or not?
#13 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 07:53 PM
Now I see its missing the tube part at the center of the top and the formed part at the bottom. Thanks for the link. That looks like a handy hitch. Kinda cool that it can go on the front or rear.
#14 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 07:55 PM
So these tractors have front, mid, & rear pto's? Are they electric then? Sorry for all the questions. I love the looks of these old AC's but never had one, just have had the newer ones.
#15 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted June 13, 2016 - 07:57 PM
And it looks like the chain bracket is there but just in the wrong location as talntedmrgreen pointed out. I think that's what he was referring to
