DIY Starter Cable
8 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 5,667 Thanks
  • 3,374 posts
Posted June 12, 2016 - 11:05 AM
Yeah I know some might think what a waste of time or minute but I get a lot of satisfaction fabricating something I don't have to buy out of things I already have. The nearest hardware store is 24 miles round trip besides it was raining, feeling lazy & wanted to just relax & not get real dirty that day.
I went to start my GT the other day & no go...broken starter wire at the gromment. I used a piece of #6 braided copper house wire, a few peices of 1/4" ID soft copper tubing, & some heat shrink tubing.
I cut the copper tubing about 1 1/4" & pressed flat about half that in a vise. I also pressed a little angle corner near the wire shank to make it more ridged...got to be professional even in the small things.
I then soldered the wire inside the tubing pocket & covered with the heat shrink tubing. Don't put the HST on before you solder, slide it on after the heat cools off....I know this for a fact. :D Drill the holes accordingly & round off the edges.
I made several of these to make my time more beneficial. Thanks for looking!
  • limebuzz, Alc, hamman and 11 others have said thanks
#2 jms180 ONLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted June 12, 2016 - 11:53 AM
I like it when a person uses what is available at the time. A fine piece of work.
  • boyscout862, Bmerf, KC9KAS and 1 other said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,311 Thanks
  • 9,782 posts
Posted June 12, 2016 - 12:49 PM
Thanks for the idea. Pretty easy to make a heavy duty cable that way.
  • boyscout862, Bmerf and Sawdust have said thanks
#4 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted June 12, 2016 - 04:16 PM
Good looking fix!
  • Bmerf and Sawdust have said thanks
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted June 12, 2016 - 09:50 PM
  Good job!! Necessity is the mother of invention, you needed it and saved some $$ too.
                                           Mike
  • Sawdust said thank you
#6 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted June 13, 2016 - 07:13 AM
I've made a couple like that also, yours looks a lot better than mine did :thumbs:
#7 John Arsenault ONLINE
John Arsenault
  • 2,585 Thanks
  • 1,213 posts
Posted June 13, 2016 - 07:22 AM
I make mine to, I solder with a torch and it makes cable making really fast. Plus you can never get the exact length you need with the exact tips.
#8 Cheetah OFFLINE
Cheetah
  • 57 Thanks
  • 57 posts
Posted June 16, 2016 - 08:10 AM
Thank you for sharing this. I have a few tractors needing new wires, and this will tip will work out nicely
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 16, 2016 - 08:28 AM
Been there, done that!
