Craftsman Lawn Tractor 15.5 Kohler
12 replies to this topic
#1 LuCarp06 OFFLINE
LuCarp06
  • 23 Thanks
  • 38 posts
Posted June 10, 2016 - 08:38 PM
After about 20 minutes of using the tractor it shuts off. After about two hours it will restart, any ideas?
#2 EricFromPa OFFLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted June 10, 2016 - 08:49 PM
Low compression or the Coil is going bad.Kohler coils act like that when they are about to go.Once they warm up a bit they just quit,Cool the coil down and they restart.
You might have a bunch of grass and dirt buildup under the blower housing.That will cause the coil to overheat and burn out.
I like those OHV Kohler command engines.Real good power and very smooth running.
  • LuCarp06 said thank you
#3 LuCarp06 OFFLINE
LuCarp06
  • 23 Thanks
  • 38 posts
Posted June 11, 2016 - 06:24 AM
It's been a great tractor for 18 years, thanks for the reply
#4 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted June 11, 2016 - 07:52 AM
In order of cost. Gas cap vent. fuel filter, coil.
#5 LuCarp06 OFFLINE
LuCarp06
  • 23 Thanks
  • 38 posts
Posted June 11, 2016 - 04:16 PM
The fuel filter would make that happen. I just thought if the fuel filter was bad it wouldn't run at all.
  • larrybl said thank you
#6 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted June 11, 2016 - 07:31 PM
Bad or collapsed fuel line too. Just trying to get the cheep fixes out of the way before diving in to the $100 + items that could cause this.
#7 LuCarp06 OFFLINE
LuCarp06
  • 23 Thanks
  • 38 posts
Posted June 12, 2016 - 06:57 AM
Appreciate that! I'll take a look today and see what I find
#8 John Arsenault ONLINE
John Arsenault
  • 2,601 Thanks
  • 1,219 posts
Posted June 12, 2016 - 07:10 AM
The first thing I do is determine the issue. When it stalls pull the spark plug see if its wet or dry, just that tid bit of info will avoid a lot of guessing. If its wet you can forget about the fuel filter , gas cap vent , bad or collapsed fuel line. Low compression normally leads to an engine that will smoke a bit , it also should not cause you to shut down like that.
Keep on guessing guys!
I can lean towards the idea that you may have a bad coil and if so your plug should be wet when you pull it.  But I would like to know how it runs before it dies ...does it start to spit and sputter or does it just shut down?
#9 MH81 OFFLINE
Posted June 12, 2016 - 07:31 AM
I have had engines that heat up and the valves stick. Cool down and they run again...
  • holdenboy1960 and LuCarp06 have said thanks
#10 John Arsenault ONLINE
John Arsenault
  • 2,601 Thanks
  • 1,219 posts
Posted June 12, 2016 - 07:46 AM
If that happened I bet he would say it turns over really easy when he tried to restart it.
#11 LuCarp06 OFFLINE
LuCarp06
  • 23 Thanks
  • 38 posts
Posted June 13, 2016 - 11:58 PM
No change at all when it shuts down, runs fine and them shuts down almost like you turned the key off
#12 John Arsenault ONLINE
John Arsenault
  • 2,601 Thanks
  • 1,219 posts
Posted June 14, 2016 - 06:30 AM
Ok next thing to do is pull the plug when it shuts down. Check for two things...1st see if the plug is wet if so it rules out a loss of fuel issue. Now with the plug out  check it for spark. My best guess at this time is your losing spark. But lets see what the plug tells us.
#13 lrhredjb OFFLINE
lrhredjb
  • 700 Thanks
  • 572 posts
Posted June 16, 2016 - 05:21 PM
I would put some anti seize on the plug thread before you try pulling a plug out of a hot aluminum cylinder head. Sometimes the threads will be damaged.
