What about something like this?
22 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted June 10, 2016 - 04:41 PM
I am getting close to closing a deal on this 1965 F100 - A little bit high in price at $4500 , but this thing is solid .
Big block 400 from a 74' LTD -C6 Automatic tranny. Every piece is here - all chrome and lights , not a dent , minor bondo in spots.
I really like this thing and feel that it has great potential as a hauler for my tractors. And it will look good :smilewink:
I went over every inch of it top and bottom , no real red flags .
It has been sitting a couple years and needs to be resurrected . I think it is a great find.
Edited by MGP59DB, June 10, 2016 - 04:42 PM.
  • Gtractor, MH81, hamman and 6 others have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 10, 2016 - 04:50 PM
Its nice for up there..but down here they would have a fit over the rust..its a nice truck!!!
  • MGP59DB said thank you
#3 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted June 10, 2016 - 04:54 PM
Cool!  Nice year for Ford, but goofy engines at times, guess that is changed anyway!  Any more those big prices are what they get for older stuff. Threw me out of market for early 50's Chevs, they want 2 to 3,000 for junkers anymore.  $20,000 of more for finished or rodded ones.
#4 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted June 10, 2016 - 05:07 PM
Yes , up here you don't see these and this was a N. Carolina truck before it came here so it has very little rust .
I have seen these RestoModded and they go from 25-35K  In decent running and looking 12K and up .
I just want something that 'I' can fix , I am tired of paying the long dollar because a sensor went out and it is 700$ to look at.
I opened the hood on this thing and I see a V8 motor - not a bunch of hoses and plastic covers .
  • Gtractor, hamman, KennyP and 8 others have said thanks
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 10, 2016 - 05:42 PM
I would drive the wheels off it for $4500..thats not a bad price really..bet they will come off that even..
  • hamman and MGP59DB have said thanks
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 10, 2016 - 05:43 PM
C-6 is almost indestructible..
  • Gtractor, hamman and MGP59DB have said thanks
#7 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,341 Thanks
  • 4,958 posts
Posted June 10, 2016 - 06:27 PM
That's an awesome pickup!!!
Has a 66 grille but otherwise a 65 is the same.  65 is the first year for the twin I beam front end.  They are OK for a daily driver.  They wander all over the road when loaded.
  • hamman, MFDAC and MGP59DB have said thanks
#8 EricFromPa OFFLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted June 10, 2016 - 07:12 PM
Yep that's a good one.I really miss our old 67 long bed.
You might want to upgrade the radiator to a nice 4 core aluminum unit.Those 400s like to run a little Hot.It more than likely had a 6 cylinder in it originally.
What gears are in the rear?
  • Gtractor, hamman, Auburn David and 1 other said thanks
#9 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted June 10, 2016 - 08:11 PM
Good advice, most overlooked item when doing an engine swap!
#10 JBRamsey ONLINE
JBRamsey
  • 1,470 Thanks
  • 841 posts
Posted June 10, 2016 - 08:58 PM
That's because you can barely build a nice rod for less than 20. Especially if you swap to a Mustang II crossmember, A arms and steering. You can put a cutout Nova clip on the chassis, but you better be very sure of your welding skills. Change out the rear suspension and drop a 9" in. Rebuilding a small block with a mild cam, aluminum intake and even a Quadrajet is not cheap. Then you have paint and interior work. Plus wheels and tires. You can do steel rally's relatively inexpensive but if you want alloy wheels hold on. You can drop 2 large on paint supplies only to sand most of it off and leave it on the floor.
That's why rat rods or getting so popular. You can drop your 50 Chevy pickup on an S10 chassis and running gear. Patch the floor board holes and you're almost in business.
  • toomanytoys84 and MGP59DB have said thanks
#11 JBRamsey ONLINE
JBRamsey
  • 1,470 Thanks
  • 841 posts
Posted June 10, 2016 - 09:00 PM
My daddy had one just like that that he and one of my mom's cousins used to sell back and forth to each other every couple of years. $ 200 each time. Should have bought a field full of them. Shoulda. Woulda. Coulda.
#12 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,921 Thanks
  • 5,972 posts
Posted June 10, 2016 - 09:56 PM
Nice old truck. Body work is what always scares me. I found a really nice 71 nova last week. Great price but needed paint and some minor rust repair. I passed since I knew I couldn't do what it needed and wasn't going to drop thousands on a paint job...
#13 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted June 11, 2016 - 04:10 AM
I am not sure about the rear gears yet , It looks to have an oversize radiator .
Just in case my Uncle has a complete 6 cyl. sitting in a garage, tranny and all with all the peripheral stuff still on it.  Only need to find a clutch assembly and the linkage for the 'tree' This one comes with the original 3tree column .
It will be a lot of work .
  • TomLGT195 said thank you
#14 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted June 11, 2016 - 04:59 AM
That's a great price for a nice daily driver. My son put a lot of time, money and effort into his 64 rambler. And it's a daily driver. Cheaper to buy them done than do them.
Noel
#15 John Arsenault ONLINE
John Arsenault
  • 2,601 Thanks
  • 1,219 posts
Posted June 11, 2016 - 06:34 AM
not trying to scare you but be careful with "minor" bondo spots. If this truck was restore and or repainted in the past it can be hiding a lot underneath the putty.
In the photo below you will see what appears to be a little rust.
In reality it ate the whole wheel well
Takes a lot of work and money to get these projects back together.
Same car
The windshield
  • toomanytoys84, Auburn David and MGP59DB have said thanks
