Very specific question regarding john deere 300/ kohler k341
10 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,337 posts
Posted June 10, 2016 - 03:52 PM
How much gas per hour would a john deere 300 with the kohler k341 burn at full throttle pulling tillage equipment?
I plan on pulling a 7 s tine cultivator and a small disk I picked up a while ago...
  • fernandofr4 said thank you
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 10, 2016 - 03:58 PM
Purple.
  • Greasy6020 said thank you
#3 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted June 10, 2016 - 04:57 PM
Miles per Pull???  You bring up some weird stuff at times.   Diesel is cheaper and last longer, Gas, just buy 5 gallons in a can and use as needed, the heck with worrying about how many hours your gonna get.  Working this stuff Uses fuel.  That is not a very big engine and it will work even harder than say a bigger twin or something else.. You ever think about an IH Cub or A or B for the stuff you want to do?  Could pull easier, last longer and bet easier on fuels.
  • Bolens 1000, propane1 and Greasy6020 have said thanks
#4 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted June 10, 2016 - 05:03 PM
I never figured out the fuel per hour. Just gripes me when the can is empty.
  • backwoods, dropped82, propane1 and 1 other said thanks
#5 propane1 OFFLINE
propane1
  • 8,448 Thanks
  • 4,030 posts
Posted June 10, 2016 - 05:38 PM
That depends on how far the governor has the throttle open under those conditions. Could be any where from 1/4 to full throttle and varied as the load changes. My guess is 2 litres per hour.
Noel
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
You will just have to run your own test..every engine and situation is different..even the weather affects usage..gonna be hard to pin down..I say Purple when I am left speechless or have no clue BTW :thumbs:
  • Bolens 1000, Paulgo and Greasy6020 have said thanks
#7 Leonard VanCamp ONLINE
Leonard VanCamp
  • 488 Thanks
  • 381 posts
Posted June 10, 2016 - 05:57 PM
Also depends on how deep your running the cultivators and disk. Soil conditions will also affect the fuel usage.
#8 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted June 10, 2016 - 08:14 PM
You most likely will be working it about as hard as if you were mowing. As Noel said above, half gallon- two liters is a close guess.
#9 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,337 posts
Posted June 10, 2016 - 08:25 PM
Awesome thanks guys!!
#10 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted June 11, 2016 - 01:06 AM
I've the same opinion as Noel and say 2.5 litres per hour with towed load
Edited by jd.rasentrac, June 11, 2016 - 01:06 AM.
#11 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted June 13, 2016 - 09:08 PM
Well i tilled 2 good sized gardens with mine on a little over half tank an i broke new ground for the 1 garden
Sent from my SM-S820L using Tapatalk
