Cub Cadet 1027 rider wheel removal
wheels
5 replies to this topic
#1 flgudmusic OFFLINE
flgudmusic
  • 1 Thanks
  • 5 posts
Posted June 10, 2016 - 10:32 AM
Hello,
I recently gave my neighbor a Cub Cadet 1027 rider, sometimes called the "Bug"? He's trying to remove one of the rear/ drive wheels in order to replace a tire but is having a helluva time getting the wheel off. What we're wondering, is it possibly 'splined' onto the axle or is there a magic spell we need to chant to get it off.
Thanx for any help,    Pat   aka   flgudmusic
#2 diesel nut ONLINE
diesel nut
  • 767 Thanks
  • 460 posts
Posted June 10, 2016 - 11:56 AM
That has 2 flat spots on the axle and 2 matching ones on the rim to hold it in place.  They were put together dry so it most likely rusted together.  When I have to get a rim off a setup like that at work the magic spell is usually an oxy/acetylene torch and an abundance of 4 letter words plus a couple days to remove it.  If the tire is bad it's usually easier to just jack the tractor up and change it where it sits.  Hope this helps.                        Stewart
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,279 Thanks
  • 6,083 posts
Posted June 10, 2016 - 12:04 PM
:iagree:  :iagree:  :iagree:
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 10, 2016 - 12:40 PM
Just leave it on and change the tire on the wheel on the tractor. Don't beat it off the transmission will break
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted June 10, 2016 - 06:19 PM
Tube it on the machine.
  • EricFromPa said thank you
#6 EricFromPa OFFLINE
EricFromPa
  • 4,198 Thanks
  • 3,368 posts
Posted June 10, 2016 - 08:43 PM
Put a tube in it while it's on the tractor.A good tube will last as long or longer than that little tractor will.
Hated my YardBug lol.Got it needing a drive belt.Put both drive belts on it and used it for 2 weeks then the drive cable broke.Replaced it with OEM cable.Was $68 for the cable btw.and mowed with it for 2 months then the carb decided to fill the block with gas and I forgot to check it before using it and it blew the connecting rod through the block.
Went and borrowed my neighbors skid loader for a couple minutes and made it fit in our small dumpster :rolling: :rolling:
Edited by EricFromPa, June 10, 2016 - 08:43 PM.
  • Eric said thank you
Also tagged with one or more of these keywords: wheels
