Kohler k301 leaking from carb
6 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 09, 2016 - 10:21 PM
If I don't shut my fuel valve off under gas tank, gas will fill up carb and drip on the floor. Does this mean gas could be entering crankcase and mixing with oil too? Carb rebuild is next.
#2 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted June 09, 2016 - 11:02 PM
sounds like the float is sticking.
I would get a kit and clean the carb good and set and float by the Kohler manual.
I use a 11/64" drill bit to set my float after put in a new needle valve
usually the gas enter though a bad fuel pump into the oil.
but gas from the carb can enter the breather tube then goes into the oil, but that is very rare.
Edited by lyall, June 09, 2016 - 11:06 PM.
  • coinman66 said thank you
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 10, 2016 - 12:24 AM
your float may be punctured or have hairline cracks in it. I had a k301 that would seem fine then after a while would exhibit the same symptoms you are having. My float was filling with fuel and the holes only showed in a pot of boiling water, after locating all the tiny leaks and soldering them the problem was gone. Just my experience hope it helps.
#4 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 10, 2016 - 07:01 AM
If it was overflowing carb, could it cause an occasional puff of smoke or an occasional backfire? It is a Cub 1250 with the Walbro carb. I've tried adjusting it with no luck. Gonna go ahead and clean carb good and rebuild it. I did notice plug was black a little wet.
Edited by coinman66, June 10, 2016 - 07:02 AM.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted June 10, 2016 - 07:09 AM
Does the oil smell like gas?
#6 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted June 10, 2016 - 07:32 AM
I think it does maybe a little? If there is, it doesn't seem like much. Carb is getting pulled off today and rebuilt. Like someone else said, I bet float has a hole or not adjusted right.
Edited by coinman66, June 10, 2016 - 07:34 AM.
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted June 10, 2016 - 07:47 AM
Change the oil anyway
