Changing Rear Tire
8 replies to this topic
#1 Hometracs OFFLINE
Hometracs
  • 1 posts
Posted June 09, 2016 - 08:29 AM
Looking for a new beadbreaker to change my rear tires on my toro gt420. Found this one online, 550, but it looks like it's on back order. Any recommendations?
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 09, 2016 - 08:58 AM
Welcome to GTT.  I use the HF bead breaker on the tire changer, but I also change out motorcycle tires as well. Here's a thread on a home made bead breaker on of our members made.  http://gardentractor...ker#entry674164
#3 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted June 09, 2016 - 09:25 AM
I use this one.  It had made life much easier.  It is a lot less work and the bead always comes off.
http://www.northernt...22827_200322827
#4 boyscout862 OFFLINE
  • 12,534 Thanks
  • 9,034 posts
Posted June 09, 2016 - 10:00 AM
Welcome to GTT. I've used the Harbor Freight one for close to fifteen years http://www.harborfre...nger-61179.html  . I bought it when it was on sale for under $30. I've changed and repaired close to 100 tires on it. I mounted mine with the shaft horizontal to make it easier(in my opinion). Three years ago, I came across a 50+ year old manual bead breaker like they had in gas stations. It was $10 and is easier than the HF. If you are in a hurry, put the tire under something heavy and use a car jack to push down and break the bead. I broke many beads, years ago, with an old fashioned bumper jack. Good Luck, Rick
  • HDWildBill said thank you
#5 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,014 posts
Posted June 09, 2016 - 12:24 PM
I use a 3 lb hammer and a Stanley"wonder bar" to break beads on gt tires at home, I wish I could bring the tire machine that I have at work.... I have plenty of air compressor capacity at home for one, My compressor there is as big as what my last 2 jobs have had to each run a full shop
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 09, 2016 - 12:30 PM
A press works well.
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 09, 2016 - 12:49 PM
:welcometogttalk:
#8 chieffan ONLINE
  • 9,563 Thanks
  • 6,405 posts
Posted June 09, 2016 - 02:16 PM
I picked up a heavy duty slide hammer type bead breaker, the kind they use on large truck tires.
Got it at an auction with a large garden cart and bunch of other junk for $15.  Haven't found one yet that it would not break.  Has wore me out more than once trying though.
  • Gtractor, boyscout862, propane1 and 1 other said thanks
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 09, 2016 - 02:40 PM
lots of times I have had luck running over the bead with my old truck..or using a bumper jack or my railroad jack NEVER fails..
Edited by Auburn David, June 09, 2016 - 02:42 PM.
