Caption This! 6-9-16
14 replies to this topic
#1 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,505 Thanks
  • 6,161 posts
Posted June 09, 2016 - 05:39 AM
:poke:  :wallbanging:  :(  :loosing_it:
  • Alc and Lmiller3358 have said thanks
#2 HANKG OFFLINE
HANKG
  • 6,610 Thanks
  • 3,534 posts
Posted June 09, 2016 - 06:02 AM
Wall unit exposed
  • Lmiller3358 said thank you
#3 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,297 Thanks
  • 10,282 posts
Posted June 09, 2016 - 06:14 AM
Half of all architects graduated at the bottom half of their class.
  • Alc, Bruce Dorsi, Lmiller3358 and 1 other said thanks
#4 propane1 OFFLINE
propane1
  • 9,726 Thanks
  • 4,509 posts
Posted June 09, 2016 - 06:32 AM
Hehe
#5 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,106 Thanks
  • 6,470 posts
Posted June 09, 2016 - 06:59 AM
when you wife really wants that new dishwasher, and you do whatever it takes to fit it in there.
Or
When you finally get that newer model dishwasher, but realize she is 22 and doesn't wash dishes, you have to make room for a dish washer.
Edited by toomanytoys84, June 09, 2016 - 07:12 AM.
  • Lmiller3358, boyscout862, jd.rasentrac and 1 other said thanks
#6 olds45512 ONLINE
olds45512
  • 1,498 Thanks
  • 739 posts
Posted June 09, 2016 - 07:52 AM
North Korean engineering at its finest.
  • MH81, Lmiller3358 and boyscout862 have said thanks
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,818 Thanks
  • 4,308 posts
Posted June 09, 2016 - 08:21 AM
A real energy saver (seldom used!).
  • Lmiller3358, boyscout862 and 29 Chev have said thanks
#8 toppop52 OFFLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted June 09, 2016 - 08:32 AM
Wall of confusion!
#9 Nxt2doc OFFLINE
Nxt2doc
  • 630 Thanks
  • 335 posts
Posted June 09, 2016 - 08:33 AM
Really Honey it supposed to be this way. Its all the rage in Europe,
  • Titus and Lmiller3358 have said thanks
#10 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 10,391 Thanks
  • 3,374 posts
Posted June 09, 2016 - 09:04 AM
The door doesn't open all the way
I wonder if it was designed that way
Tough to get dishes in and clean
As the door always stops with a bit of a lean
It hits the wall with a sudden halt
Instead of laying down flat without a fault
Stuck in a corner it should never have found
It will make the user get a little wound
To insert a pan with a handle is hard
Might need to use a little Lard
The trays roll out a little bit
And then they stop when the door they hit
Built in for looks and not for usage ease
This dish washer is a bit of a tease
Not to mention what happens when it stops working
You will have to remove some trim and do some jerking
To get it out to fix the problem
While you curse the installation goblin
  • Lmiller3358, oldedeeres, Sawdust and 1 other said thanks
#11 oldedeeres OFFLINE
oldedeeres
  • 10,649 Thanks
  • 5,163 posts
Posted June 09, 2016 - 10:23 AM
Why you should never build a house around an appliance.
or
What came first, the washer or the wall?
  • Lmiller3358, LilysDad, HANKG and 1 other said thanks
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 09, 2016 - 11:29 AM
DOH!!!
  • Lmiller3358 and HANKG have said thanks
#13 Lmiller3358 OFFLINE
Lmiller3358
  • 1,567 Thanks
  • 1,468 posts
Posted June 09, 2016 - 01:43 PM
I see my dumb a$$ brother in laws at work again !
  • MH81, oldedeeres, HANKG and 3 others have said thanks
#14 MH81 OFFLINE
  • 29,979 Thanks
Posted June 09, 2016 - 02:17 PM
Recently in a home where you had to open the oven door to open the perpendicular dishwasher.
Way to go architect :thumbs:
  • 29 Chev said thank you
#15 karel OFFLINE
karel
  • 2,417 Thanks
  • 1,538 posts
Posted June 09, 2016 - 02:27 PM
Non city inspected ilegal rouge triple decker third floor apartment in Worcester.
