gas in oil
case
5 replies to this topic
#1 case1man OFFLINE
case1man
  • 189 Thanks
  • 135 posts
Posted June 08, 2016 - 08:27 PM
Fuel pump pumped gas in oil changed oil twice any thing else I need to do?
  • oldedeeres said thank you
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 08, 2016 - 08:40 PM
Fix your needle and seat in the carb
  • case1man and Auburn David have said thanks
#3 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted June 08, 2016 - 09:12 PM
fix or replace the fuel pump.
If you have a Kohler with the fuel pump on the motor the diaphragm is bad and it leaks gas into the oil.
  • case1man said thank you
#4 case1man OFFLINE
case1man
  • 189 Thanks
  • 135 posts
Posted June 08, 2016 - 09:18 PM
replaced fuel pump before oil change ran it a couple minutes between changes didn't see or smell gas in oil . Do u think twice is enough.
#5 oldedeeres OFFLINE
oldedeeres
  • 9,463 Thanks
  • 4,754 posts
Posted June 08, 2016 - 11:51 PM
I had the same problem with the J.D.STX38 this spring and it has a Kohler. My neighbour came over and checked it out... the carb was gummed up some and has a lot of play here and there. Since it was new in the early '90's, and has never caused a problem before, I guess I can't complain.
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 09, 2016 - 09:02 AM
You should be OK.  Just keep an eye on it for a week or so.
Also tagged with one or more of these keywords: case
