Hello - 61 Electric start Model.
I am having an issue right now.
Ive replaced the voltage regulator and wired it according to the manual...motor turns over fine. Now I'm confused a little. It have points, which are connected to a wire going into the engine (Magneto?).
The points are wired separately from the starting..so, you push the button...starter turns over...my assumption is the points get spark from the magneto??
Im not sure whats going on...new points, gaped correctly...it will start once in a while...but not at all consistent. what should I be looking for..
Thanks in advance
Tom
