How to Turn on a Laptop Mousepad
9 replies to this topic
#1 DougT ONLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
Posted June 07, 2016 - 08:43 PM
I've got a Gateway laptop running windows 8.1. I set some stuff on the keyboard and now the mousepad don't work. I've search and can't seem to find anything. The wireless mouse still works but sometimes the one on the laptop comes in handy. I know there was an icon or something on the old laptop that used to turn it on and off but I can't seem to find it. Any idea??
  • tracidf18 and patlv3 have said thanks
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 07, 2016 - 09:02 PM
On my Dell running win 7 I can go to the control panel, and access the touchpad settings in the mouse menu
  • DougT said thank you
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted June 07, 2016 - 09:07 PM
Reboot and see if that fixes it.
One of the Fn keys should enable/disable varies by make.
Go to start menu and mouse settings and see that nothing is disabled there.
A bad/corrupt driver could also cause this problem.
  • DougT, Cvans, HDWildBill and 1 other said thanks
#4 kellerman88 OFFLINE
kellerman88
  • 153 Thanks
  • 79 posts
Posted June 08, 2016 - 06:10 AM
Some laptops will have a little indent or other unusual looking area on the mouse pad that you can double tap to toggle it on and off.
  • HDWildBill said thank you
#5 HDWildBill OFFLINE
  • 8,984 Thanks
Posted June 08, 2016 - 09:52 AM
From your description in your post I think Ducky & Kellerman88 are your best possibilities but according to the Gateway site https://panam.gatewa...Z06E4faq5.shtml  there is no key combo's to turn it on and off.  This may be a dumb question but it seems to me I had a laptop at one time that when you plugged in a mouse the touchpad quite working.  Is this a possibility with yours?
#6 DougT ONLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
Posted June 09, 2016 - 12:07 PM
Thanks guys, I'll have to get some more time to fight with this. I know it's been rebooted a few times since it happened but I don't remember if I rebooted it with the wireless unplugged. I know they have always worked together with no problem. I can see the touch pad mouse from the control panel and it shows OK. The computer started doing some crazy scrolling and it took a while to realize the stack of paper was putting pressure. The FN key is close in the vicinity. I was pushing buttons to keep it from acting crazy but it didn't stop until I took the papers off. I do have a restore disc. Maybe I can get it to fix it without losing everything.
#7 gksyn OFFLINE
gksyn
  • 100 Thanks
  • 95 posts
Posted June 28, 2016 - 09:42 AM
Where you able to fix this or still need assistance?
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,286 Thanks
  • 6,087 posts
Posted June 28, 2016 - 12:21 PM
Device manager if you can get in there.  I'm a mouse user and hate the pad..  I always have the dang pointer roam all over the place on my desktop when I move my hands to type.  Set yours to only enable or turn on when the external mouse is disconnected.  You will have to go into the device driver software for the mousepad on your machine to find and set it up..  Good Luck!!!
Edited by WNYTractorTinkerer, June 28, 2016 - 12:22 PM.
#9 DougT ONLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
Posted June 29, 2016 - 11:01 AM
I haven't got it working yet but then I haven't had a lot time and energy to put into it. From the control panel it does show enabled. There is a strip on the right side of the pad but don't feel anything there that makes a difference. I've tried to reboot with the wireless mouse out and didn't help. That's about all the time I've had to try it.
#10 gksyn OFFLINE
gksyn
  • 100 Thanks
  • 95 posts
Posted June 29, 2016 - 12:14 PM
Would you be able to give us the model of your Gateway?
Few things to try. Sorry if you already did try them:
Turnoff Touchpad when a USB Mouse is plugged in --> Go To Control Panel and Click on the Mouse Properties Icon. Should be a setting in there called "Disable Touchpad when USB Pointing Device is present" (Make sure that's turned off if you don't desire this setting)
Worst case:
You can check your BIOS Settings (F2 when booting up) to make sure the touchpad was not disabled somehow in there.
Also, it could be a driver issue. Outdated, or recently updated driver that failed.
Lastly, it could be a hardware issue. The touchpad no longer functioning properly.
When you find time, let us know. I will be glad to walk you through troubleshooting this.
